Originally posted by: akugami
IC7 seems like an interesting product. I don't know if I'll use it, I still have a good sized tube of Ceramique and for my modest overclocking uses (most taxing is video encoding/transcoding), it's not critical or even necessary to eke out another 100mhz.
Originally posted by: OCguy
Let me post what Aigo is going to say before it is even said:
"Who the hell uses air cooling????" 😛
Originally posted by: TidusZ
I replaced the TIM on my BFG Gtx 295 with OCZ freeze and load temps dropped ~10c. The TIM on my gpu's was caked on really thick, certainly not the thin layer on those water cooled cards.
Originally posted by: DrMrLordX
Hmm, methinks they need better machines if the hand-built cards have superior TIM applications.*
*: so long as Skynet/Cylons are not involved.
You could switch to Toothpaste or Vegemite.Originally posted by: BladeVenom
After looking at the results, I guess I'll have to stop using cheese as a thermal interface material.
Still seems kind of sad that the machines can't do a better job than that. And the general trend here is that mechanizing the process and doing it right would cost more than human laborers would. If anything, paying a guy $25/hr or what have you is generally considered to be a cost-cutting measure.
Japan's primary disadvantage, its lack of raw materials, was overcome through the building of huge vessels designed to carry large amounts of ore for low cost, building deep harbors and steel mills on the coast, and utilizing the most advanced technology. For example, 86 percent of Japanese steel is continuously cast-a process that saves energy and raises productivity-compared to only 26 percent in tile U.S.
