hard to saw wood without a saw
ElFenix
i swear there should be one in the garage somewhere... but i looked on every shelf, in every box, and could not find one at all.
so... if i have to buy something should i buy a dremel with cutting bit or a regular circular saw? need to cut regular pine 2x4
Dremel? Are you kidding? Better check the depth of the blade in the circular - it may not make it all the way through the 2x4. Can't go wrong with a good ole hand saw for cheap and easy.
S.
Score it with a butter knife, place it across two cinder blocks on the ground, and go kung fu on it, breaking it with your head.
Disclaimer: No.
Originally posted by: Pliablemoose
Take it to Home Depot & they'll cut it for you for free
yeah i saw the cutting station when i was at lowe's buying the wood...
Are you going to need a circular saw for anything else? If you only have a few 2 x 4s I'd buy a regular handsaw and a cold beer. :beer:
Dremel? hahahahaha, Elfenix pop over my house and I will let you borrow my circular saw, hand held circular saw, reciprocating saw, table saw, miter saw or compound miter saw. Any of those will work.
