I've got it! ... sort of...
If you want to follow the solution, I suggest listing it as E = 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, T = 0,1, ... etc
and cross out numbers as you go along. It'll help.
Start these equations:
1) Y+5E=Y+10a
2) a+T+5V=T+10b
3) b+R+5L=E+10c
4) c+I+5E=N+10d
5) d+H+5W=I+10e
6) e+6T=N
the lower case letters are carries
7) from 1) 5E=a10 => E=2a
8) from 2) E + 10V = 20b
since 20b is multiple of 10 and 10V is multiple of 10, E = 0. V cannot = 0 because then E = 0 also, which cannot be true.
then a = 0 from (7)
since E = 0, in eqn (6), T != 0, so T = 1 since N <= 9.
so that means N = 6,7,8,or 9, and e = 0,1,2, or 3
9) V = 2b from eqn (8)
from eqn (2), the max b can be is 5, since max of a + T + 5V < 60
10) table:
b = 0, V = 0 <== impossible, E = 0 already, b != 0
b = 1, V = 2
b = 2, V = 4
b = 3, V = 6
b = 4, V = 8
b = 5, V = 10 <== impossible, b != 5
so b = 1,2,3,or 4 and V = 2,4,6,or 8
11) at eqn(3), b+R+5L = 10c < 60 for the same reason as listed at (9)
c != 0 because b!= 0. max of c is 5. so c can equal 1 to 5.
12) from eqn(4), c+I=N+10d. c != 0, so max < 20. which means d = 0 or 1
13) make a table of c, N, I, d using eqns in (11) and (12), and you will find out that under all possibilities of 20 different combinations, d = 0 always.
also you will find out that I never = 9.
14) use this knowledge in eqn (5), H + 5W = I + e10.
W = 2,3,4,5,6,or 7 since e < 4. in fact, max of I + e10 = 38.
if W = 2,4,6, then H = I, which cannot be true. so W = 3,5,or7
when W = 3,5,or 7, then e cannot be 0. therefore, N != 6 in eqn (6).
15) you can look at eqn (14) as H+5 = I mod 10. since I != 0,1,9, to satisify this eqn, H != 4,5,and 6
at this point, you should have H = 2,3,7,8, or 9. As H+5 = I mod 10, the corresponding I to each H is 7,8,2,3,4. These are the possible I's.
16) from eqn(3), b + R + 5L = c10
since L != 0, c != 0.
if L = 2,4,6,or 8, then you can look at this eqn as b + R = 10
then do a list of tables as in (13)
L = 2
b = 1, V = 2, R = 9 <== L = V, bad
b = 2, V = 4, R = 8
b = 3, V = 6, R = 7
b = 4, V = 8, R = 6
L = 4
b = 1, V = 2, R = 9
b = 2, V = 4, R = 8 <== L = V, bad
b = 3, V = 6, R = 7
b = 4, V = 8, R = 6
L = 6
b = 1, V = 2, R = 9
b = 2, V = 4, R = 8
b = 3, V = 6, R = 7 <== L = V, bad
b = 4, V = 8, R = 6 <== L = R, bad
L = 8
b = 1, V = 2, R = 9
b = 2, V = 4, R = 8
b = 3, V = 6, R = 7
b = 4, V = 8, R = 6 <== L = V, bad
for L = 2, c = 2,
L = 4, c = 3
L = 6, c = 4
L = 8, c = 5.
remember, 1 <= b <= 4, so this is as far as it goes.
there are some invalid combos such as L =2, b = 1, V = 2, R = 9, etc,.
if L = 3,5,7,or 9, then (b + R + 5) mod 10 = 0.
then
L = 3
b = 1, V = 2, R = 4
b = 2, V = 4, R = 3
b = 3, V = 6, R = 2
b = 4, V = 8, R = 1 <=== remember that T = 1? so this is no good.
L = 5
b = 1, V = 2, R = 4
b = 2, V = 4, R = 3
b = 3, V = 6, R = 2
L = 7
b = 1, V = 2, R = 4
b = 2, V = 4, R = 3
b = 3, V = 6, R = 2
L = 9
b = 1, V = 2, R = 4
b = 2, V = 4, R = 3
b = 3, V = 6, R = 2
for L = 3, c = 2
L = 5, c = 3
L = 7, c = 4
L = 9, c = 5
notice R never = 5 and c never = 1.
there are only 2 valid cases of b = 4 : L = 2, R = 6, b = 4, V = 8, c = 2 & L = 4, R = 6, b = 4, V = 8, c = 3.
Since there are only 2, I manually tried these 2 cases, and they don't work. Conclusion: b != 4.
there are 7 valid cases of b = 2, and I tried these manually too, and they don't work also. b != 2.
(I didn't want to do this too but I was stuck)
following this new revelation, if you made up a table, you'll see that R != 3, 6, and 8. so R = 2,4,7,or 9.
17) at this time, only L, V, and Y can be 6.
since Y is the left over number, as it works with any number, I decided to leave it. (this is a pretty big assumption) so its only L and V.
with my "trusty" table, see that there is only one valid case of L = 6: R = 9, b = 1, V = 2, c = 4.
solving for more variables, I found that it doesn't work! so V = 6, L != 6.
V = 2b, b = 3.
18) eqn (3): 3 + R + 5L = c10
then letter left to find are for 2,3,5,7,8,9
only 2 and 7 for R would work for the above equation.
19) if you've been checking numbers off, only I and L can be 4 (excluding Y). 2 possible cases of L = 4 in the table --- they don't work.
so I = 4.
20) rewrite eqn (4) and (6) c + 4 = N, e + 6 = N ==> c = e + 2.
since e = 1,2,or 3 and c = 2,3,4,or 5, that means c != 2.
actually, here at this point, there only 7 valid cases for the L-R-b-V-c combinations.
the correct one is L = 7, R = 2, b = 3, V =6, c = 4
plug back in, and do some easy algebra,and you get br0wn's answers.
E = 0, T = 1, I = 4, N = 8, W = 3, H = 9, Y = 5, V = 6, R = 2, L = 7,
plus the carries: a = 0, b = 3, c = 4, d = 0, e = 2.
Conclusion:
basically after about 10 minutes I didn't feel like trying to do more derivation and look for super subtle equations, and had to resort to looking for numbers that are easy to eliminate. Probably verified about 15 sets of numbers to find the right one. at least it was better than 8! sets of numbers
once at 16), you can basically just try all 23 possible sets and see which one is right. which is probably what I would've needed to do if it turns out that Y = 6 (my assumption was that Y != 6)
This took me an hour to do. and another 1/2 hour to write
