Ok so heres the problem.
I have a Intel 975XBX mobo and Im trying to setup a RAID 0 array on 2 36gb raptors.
On boot it allows me to go into the Silicon Image Inc RAID utility through which I initially setup the array. Was very easy.
Then I installed XP and all was good.
Then I tried installing my mobo CD and I got a PXE-61 media cable error.
I thought it had something to do with my drives so I removed the partition and then tried to install XP again. (that was my 1st mistake cuz now i know it had nothing to do with my drives then but just a simple boot to network thing that i had to disable in BIOS)
Between all this I managed to pick up a newer version of XP with SP2. Tried installing it and this time it wouldnt detect my HDDs.
On the reboot I realized that the RAID utility is detecting them so I setup a RAID 0 array again. XP still wouldnt detect it.
Now the funny part is that my BIOS detects the raid array but not the individual drives and I have no idea where the problem is.
So to summarize:
On IST Windows install
- used older disk
- setup raid array
- windows installed
- all good
On 2nd attempt
- used newer disk with SP2
- setup raid array
- windows dosnt detect HDD's
- BIOS detects raid array as a drive
On 3rd attempt
- deleted raid array and kept it as 2 disks
- windows dosnt detect any HDDs
- BIOS dosnt detect any HDDs
- RAID utility still detects them and lets me format em, setup an array etc
- With the array up the BIOS detects them
Did i screw something up to the point where I have to now discard it? (I pray that I didnt)
If not, what could be the problem?
So to summarize:
- used older disk
- setup raid array
- windows installed
- all good
On 2nd attempt
- setup raid array
On 3rd attempt
