AiponGkooja
Ok, update again. Was doing tons of homework and studying, and getting really sick of it, and I happened to look over at my computer. Decided to drop the homework for a bit and go at my computer with a screwdriver and just pull parts out and unplug stuff on my way to taking ASUS's advice and pulling the mobo out of the case to check for possible "grounding/emi interference problems." So here's how it went:
-Unplugged both DVD burners and floppy drive
-took out my X-Fi sound card
-replaced my 6600gt with the 7800gtx replacement that I got a while ago
-loosened the screws mounting the motherboard into the case (just loosened screws, did not remove mobo from case)
-disabled the SiL raid controller
-disabled the nvidia raid controller
-moved both hdds to the "regular SATA" ports
-turned on computer
Computer booted. It asked if I wanted to boot Windows in safe-mode. I said boot normally. It did. Both hdds work. All my data is still here. Everything works. I'm a happy little man. The End
Thanks all,
Aip
-turned on computer
Thanks all,
Aip
