Ok heres my current problem i'm dealing with.
Here goes okay i just updated my main OS boot drive to a 320gb western Digital SATA drive, Before it was a 160 IDE Seagate drive and my Data Drive was also a IDE 500gb WD drive. So i installed my new drive and did a fresh install of Windows 7 32bit the install was prefect and it boots just fine but my Damn Data is not showing up in windows. It shows up during the boot process as a Master
It even shows up under device manager but windows will not display the drive.
I've tried multiple jumper settings and i've even tried setting it as a Slave no go, and i've tried no jumper and setting the SATA as Master.
I have a Gigabyte p35 DS3L with 2 Sata devices (boot drive and DVD drive)
before i did a fresh install i save almost all of my files to my Data drive. Before i fresh install i was running RC windows with my main drive being IDE and i never had a problem.
Any help is appreciated. Thanks
I figured this was probably a better place to post this. So if possible can a mod delete the other thread in General Hardware. Thanks.
