Hard drive: Do I really need 7 passes to securely wipe it?
rudder
19,441
86
Your data would need to be very valuable or the feds are investigating you for child porn. Otherwise.. not likely the average user will spend the time or money to undelete everything after a secure 1 pass delete.
Blain
Blame the paranoia on Leo.
MagickMan
7,460
1 pass is enough. All the talk of NSA and DOD levels of erasing are from years ago when drives were thousands of dollars and reused often, the government doesn't even use software to erase drives like that any more. They shred the drives and place the shreds into an induction furnace which is hotter than the sun which produces a liquid metal slurry.
This. Even in the area where I worked, which was a lower security research facility, we just destroyed the drives. I had an incredible collection of HD magnets and used the platters to make wind chimes.
Russwinters
409
I like to remind people that are worried about it that the whole purpose of a hard drive is to store information. Drives would be pretty useless if you can write a 0 then a 1 and if you read it enough the last bit you wrote will suddenly make itself known. Imagine a drive that flips bits depending on how many times you read or wrote the bit, ugh, data would be garbage.
Indeed, but here is the "kicker"
Writing 00s to a drive doesn't REALLY write 00s.
The fact of the matter is that the data is interpreted by the read heads. The read heads detect magnetic flux changes on the surface. Basically a change in the polarity equals a 0, and no Change equals a 1.
These mean that no specific polarity equals a 1 or a 0, it is the change, or lack of change that represents the binary.
A problem arises because the read heads will run into two serious issues: If a string of "No change" is too long the read heads will not be able to properly interpret the data, basically it will lose it's way, and at the same time if there are too many flux reversals in a area the magnetic domains may suddenly change polarity which is obviously BAD for data storage.
But software commonly has long strings of 1s, or 0s in it's coding. So The hard drive actually re-encodes the data into something it can safely use, and the decodes it on the fly when it is read off of the platter.
This is where RLL encoding comes in. HDD still use a evolved form of RLL encoding (Run Length Limited) Which basically means the HDD uses it's own binary based off of the rules: we cant have too many 1's or 0s in a row (maybe more then 4).
So when you write 00s to a drive, it is actually not writing all 00s at all.
nerp
9,865
105
A lot of people think their data is a lot more valuable, interesting, important or incriminating than it reallly is.
