- Nov 30, 2005
- 50,231
- 118
- 116
Originally posted by: Common Courtesy
You are at work, so this will not help at present.
However, a swim into COLD water will clear it quickly.
Hangovers are smart, they do not like the cold. Unlike the stupid host that collects a hangover in order to suffer.
Originally posted by: joesmoke
Some chiba works REALLY well if thats you kinda thing.
Originally posted by: zinfamous
here's a good article on the matter. probably too long for most on here, though
text
couple of things to consider:
-water is generally the best remedy. plenty before, and after drinking, before bed. the most effective way is to drink water in between drinks...but you'd never get hammered, so what's the point? (assuming this is your goal)
-never, ever, take ibuprofen (or is it aspirin? I forget) while drinking, or soon after/before consuming alcohol. It will tear your liver to shreds.
-The Bloody Mary was developed as a hangover cure. It works, kinda....but it just delays the onset of the methanol processing (the worst part of the hangover), as you introduce more ethanol into your system (which is more readily processed by alcohol dehydrogenase, the enzyme that processes ethanol/methanol).
actually, this is the best method I have ever come across. Toking while drinking has always guaranteed no hangover for me in the morning, as well. (must be quality, though...)
I am going to have to try that. I have never heard of taking a swim to help your hangover. I am actually a little suspicious of this suggestion.![]()
text
Key word in the suggestion is in CAPITALS.
Stumbled into a pool (Northern New England) - late May) after HS grad party with my first hangover. (Only one since then)
We had taken the cover off the week-end before and there was a film of ice on the surface.
Wet suits had been used to remove the inlet/outlet pipe plugs.
I went in to the bottom, the hangover must have stayed on the surface.
By the time I dried off, I was clear headed.
Then I somehow failed last night...:frown:
text
I think you are thinking about Tylenol... acetaminophen is fairly hard on the liver, in combination with alchohol it's really bad. NSAID's (Advil/Ibuprofen, Aleve/Naproxen) can be hard on your stomach, they can cause ulcers, I think alcohol increases that risk.
God, ever sense my pharmacist bud told me about "micro bleeds," I've been terrified....
Originally posted by: Capitalizt
I actually researched this a while back during a particularly bad hangover. The SCIENTIFIC CURE is Vitamin C and lots of water. Alcohol drains the vitamin C from your body leaving you sick feeling and off-balance.. So the cure is a big glass of orange juice (or a vitamin C pill) followed by plenty of water. That will kill and prevent hangovers. Every time I drink heavily, I pop a vitamin C pill and have a glass of water before bed. It works every time.
