I just replaced my HAF-X I/O front panel, and there is one wire on the new one that the old one did not have. I am wondering what it is for?
It appears to be a grounding wire I assume? If so how exactly would I ground it? The wire is pretty short, and I don't know where to ground it to. As many of you know the Haf-X is textured painted steel, not exposed aluminum, am I too mount it to the nearest screw hole and fasten it to the case with a screw? What if I cannot reach the closest hole?
