It seems like the P55M-UD4, but its been discontinued.
shall give that a try, but since system won't even let me boot into desktop, so guess will have to install the system again. thanks for the suggestion.
Okay, after testing the Cartri BIOS for awhile now, I cannot say I'm very impressed at all with it. It does seem to work okay for Snow Leopard, as long as you continue to use DSDT and the kext necessary to make SL run, so what's the point? My Windows 7 install will no longer boot, but I understand if I reinstall it with the BIOS settings as they are it will work fine then. Major PITA to me, but at this point that is probably what I will do to get it going again.
I built one of these for a friend recently- it does seem to be a very nice board for OSX.I just upgraded to an MSI X58 Pro-E: (the one without USB 3.0 & SATA 6G)
http://www.newegg.com/Product/Produc...-226-_-Product
I had this same problem with the MSI Hack and GT250/1GB card while using the VGA connector. (Card has VGA, DVI and HDMI). I got blue screen only- even with repeated reboots.hack boots fine, but gets stuck at the blue screen just before showing main desktop. Any suggestions?
I just ordered my UD3P replacement consisting of the following items:
MSI P55-GD80 mobo* Intel Core i5-750 CPU* 4 Gb Corsair RAM * (3) GeForce 9400 GT (512 Mb) * Hitachi 1 Tb hard drive * HEC case w/585 Watt PSU
My plan is to get a basic system running Snow Leopard using only 1 video card and eventually get it up to 3 video cards for use with 6 monitors. The MSI board supports 3 PCI-E video cards. I also left the door open to upgrade later to 8 Gb RAM as I bought 2-2 Gb sticks for the first 4 Gb. NewEgg has a special deal on the 9400 GT if you buy 3 you get them for $47 each, plus there is a $30 mail-in rebate also. Should be a neat system once I get everything sorted out.
NASA Hackintosh Central Command...I can see it now 😀
Any thoughts on whether 10.6 would install on the Zotac ZBOX HD-ID11 NG ION?
http://www.newegg.com/Product/Produc...82E16856173005
