Hackintosh 10.5.5 Retail Rig - Starting at $305
Page 133 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
vailr
54
Originally posted by: DougoMan
Here is a weird problem I am having with my DS3L.. I am trying to charge my primary boot drive in the BIOS and cannot do so because my keyboard does not have a number pad. For some reason the - and + on the regular keyboard do not work.. Is there any way around this?
Did you try using the "Del" key?
mosslack
902
hq-a.weebly.com
Originally posted by: DrAwkward
I got by that okay, but I get the DRM error when trying to watch a movie on 2 out of 3 of my Hacks. One is because of Snow Leopard I'm sure, but the other one I have no idea of why this is happening.
This tip solved my DRM 8152 errors:
http://groups.google.com/group...read/8f4e52f83a1e3183#
Nope, didn't work. My network interface was set to en1 and this tip changed it to en0, but I still get the DRM error with Firefox and Safari on my GA-945GCMX-S2 running 10.5.8. The other system I'm having this problem with is the UD3P and it's running SL so I think that is a different problem.
smokozuna
52
I could use a little help guys. I am ready to upgrade to Snow Leopard and was hoping you guys could confirm I am on the right track, please. I would like to purchase the G31M-E2SL board,not knowing which revision, 1.0 or 2.0, Newegg is going to ship me I would also purchase SYBA SD-CM-UAUD USB Stereo Audio Adapter and Trendnet Gigabit TEG-PCITXR (PCI) Ethernet Card. If my research is correct by purchasing these 3 items then following the latest LifeHacker guide I should have a Pure Vanilla install, correct?
Motherboard
http://www.newegg.com/Product/...x?Item=N82E16813128357
Sound
http://www.newegg.com/Product/...2186035&Tpk=syba+audio
Ethernet
http://www.newegg.com/Product/...x?Item=N82E16833156139
Guide
http://lifehacker.com/5360150/...pc-no-hacking-required
Stell's compatibility guide
http://stellarola.tumblr.com/p...ce-compatible-hardware
EP45UD3P Guide works for the G31M-ES2L
http://www.infinitemac.com/f57...acking-required-t4223/
vailr
54
Save some money: why not try using the onboard audio, at least. And maybe the onboard LAN as well?
Install Leopard first, it's much easier to set up than Snow Leopard.
smokozuna
52
Because the LAN used in Rev 1.X is RTL 8111C which is supported but in Rev 2.X they changed the LAN to the AR8131 chip which has no support.
DougoMan
813
I just did. It does not do anything..
KeypoX
3,655
why would you need a num pad. You use the Page up and Page down buttons.
DougoMan
813
I was wondering what PD/PU stood for. Thank you. Now what I am wondering is if I hook up the wireless Apple keyboard I have: it has no Page Up or Page Down. Maybe I should stick with the one I have?
DougoMan
813
Ok now I have a real problem.. I thought it would be fun to put OSX on a RAID 0 array, which I did through Disk Uitility and it installed fine.. But I have no idea how to boot it. Using Boot 132 I do not find the drive on 80,81,82 etc. Help?
Kaido
Feb 14, 2004
50,949
6,883
Software or Hardware RAID?
DougoMan
813
Software.
Kaido
Feb 14, 2004
50,949
6,883
Software.
Software RAID is tricky - you have to install OS X to a single drive first, then clone it and add the UUID to the Boot Plist, that way the bootloader knows that it's a RAID software array. Since the Software RAID only exists in, well, software, you can't setup the array & then install it to because the software isn't on the drive yet, if that makes sense. Chameleon RC3 is supposed to have native support for this, but I don't know if that means it actually works now, or if they've made it easier :D
Jack Flash
1,947
Just installed my ASUS WL-138g V2 802.11g PCI WiFi card in my UD3P system. Popped right up as Airport in 10.6.1 32-bit kernel.
nsiderTalon
533
Hey, are there any recommended cheap bluetooth adapters? I'm thinking of getting an Apple wireless keyboard, but I can't find any info on what the common bluetooth USB adapter is...
Jul 12, 2009
I decided to try the lifehacker guide. Followed the directions on my ud3p's and they work! Both nic's are full duplex. (I took the system to work and was on 2 networks at the same time with no trouble) audio is fine. the only issue was error 35 UUID. I added the 802.11 text to the networkspref file and it stopped that. Snow is fast on the hacks. But I then tried to upgrade an existing system that used kaidos guide. I had a working 10.5.7 with various apps, ran the lifehacker guide, and it all worked as if I tried it on a fresh clean HD. All the files were there, and they still worked! I felt it would work because snow would replace all the system files. Snow didn't have an upgrade or clean install option. Has anyone else tried an upgrade?
Dec 8, 2008
43
To Kaido or anyone else:
I'm looking for the 10.5.7 or .8 (whichever one runs better) DS3L and UD3P Kit. I have 2 hacks running 10.5.6, which I might add run wonderfully, but I need to upgrade to 10.5.7 or .8. I need to access the iTunes store (iTunes 9) but it won't let me unless I install Safari 4.0.3 which needs, at minimum 10.5.7.
Can anyone help me out with a link?
DougoMan
813
Software.
I knew it seemed too easy!
kalster
7,355
I use this one Text cheap , small and works out of the box in both SL and Leopard hackintosh
scootermaster
2,411
Beware they changed this with later revisions and it might no longer be compatible (Kaido?)
DougoMan
813
Which lifehacker guide? I'm going to upgrade to a UD3P and planned to use this lifehacker guide but it says you need to buy a seperate ethernet adapter.
nsiderTalon
533
That's what the reviews seems to say at the bottom of the product page. I think I'll go with the D-Link DBT-120, an ebay seller has them for $10ish
Jul 12, 2009
yes, thats the guide. I left my bios settings the way kaido prescribed and the onboard nics work. The system prefs show 4 built in ethernet ports, i believe en5 and en6 were the 2 I was using. I only used it for a half hour, but both nics definitely worked. Now on the bios FA machine, i used it for 4 days. no crashes, sleep works fine also. The only quirk is when you restart, you need to set the audio output device again in the prefs. btw, firewire worked fine also.
Status
