Squisher
- Aug 17, 2000
- 21,204
- 66
- 91
Originally posted by: JLee
OP: Fix your brakes...it's not hard...
It really is easy. And, the wonderful thing about brakes is the longer you put it off, the more it'll cost you to fix.
Originally posted by: geno
Originally posted by: DixyCrat
Um... this happened to my car; BREAK shoes where not changed for WAY to long and the brake cut itself open and leaked BREAK fluid everywhere. Next thing i know, no BREAKS at all. This is a 1997 chevy sonoma.
1 for 4.
Oh, ok.Brakes. Chevrolet S10. GMC Sonoma. OP has disc brakes, not drum brakes.
This is what happened.. pumping the breaks was a bad idea.if you jack on the brakes or press them hard and fast the fluid will push to the back reservoir and leak out regardless.
good point.I wouldn't want to experience the worst possible behavior from a vehicle in an evasive maneuvering situation.
If you fail an inspection and then don't you have a few days to get it fixed and can just show the cop your receipt.Do what is required to pass inspection, then pass inspection legitimately.
