[Guru3d] MSI 390X Gaming 8G OC review
It's not just the reference numbers, there's some extra perf gains in there because its not normal for R290X (even sites that use custom models) to match or beat 980. Those custom cards run at 1050mhz etc already.
Not sure where they are getting extra perf from because in my own testing, Hawaii isn't bandwidth bottleneck for the extra vram speed to help it.
That is not logical. How is 400.00 more than fair when 240.00 will do the job for the same GPU? It's an overclocked 290X with a much better cooler and 8GB of RAM that won't make a difference over current 4GB models for this card. It's a money grab card IMHO.
It's perfectly logical. They are charging what the card is worth, nothing illogical about that. The money grab card is the card that is 100.00 more for the same performance. And less memory.
The performance result looks good to me and really good temp and noise ratings imo.
Because they (hardwarecanucks) compared it to a reference 290x which honestly sucked due to the cooler. They should compare after-market 390x with after-market 290x. And then the difference between 390x/290x would be close to 0.
Anyway 290(x) aren't that cheap here anyway so I will probably get a fury. Especially because of my case. most 290(x)s don't fit...
because they wont sell R9 2xx rebrands.If AMD cannot sell R9 2xx with such a cheap price than how can AMD sell rebrands with a higher price even if they add extra vram.
I would agree, but let's see how it pans out. I certainly would not buy R390X when I know Fury/X/Nano is coming.
Maybe people who have yet to upgrade, may think twice seeing the new 300 series running cool, quiet and beating 980 for less with more vram?
It doesn't have the reputation that the R290X had, hot, noisy and power hungry (which matters when its slower). Now its quieter, cooler and still power hungry, but its as fast or faster with more vram.
If anything, it will make it more obvious that 970 and 980 are overpriced now that the hot & noisy reputation is gone.
Why would they do that? Very few reviewers actually compared the after market 290x's to anything. Most comparisons to the competition were on reference cards.
It is hard to see though, why somebody would pay 400.00 for essentially the same GPU they can get for 240.00. I do admire the lower noise and cooler running temps at 10% higher clocks though. That is a step in the right direction.
Except in the USA, nowhere else in the world you can find a R9 290X at $240.
Yup, even AT here uses the reference numbers. It was a major mistake with that crap cooler. The reputation stuck just like it happened to Fermi.
Gcn 1.1 have incredible long legs. The results looks kind of crazy for what it is. Beating a 980 on 1440 and 4k is super results.
It will be interesting if it can continue.
We have a few of the gcn cards in the house and the driver development and speed increase during the years have just been a pleasure. I am sure going gcn again. Man i was secs from buing a lot of kepler stuff and also the 970. No way today.
Its going to be fiji nano and up stuff all the way.
Bro you are forgetting that
GTX 980 Ti, Fury X are only for 3% to 5% PC user who can afford it.
Coming R9 3xx series people who were ready to spend $350 to $400 mark would not spend it o R9 3xx series because they already have R9 290X or GTX 970 or GTX 980.
I say it is a very bad time for rebrand and of course AMD is very late and they should had something new at cheaper so that it would have appeal to people.
That reference cooler on 290x was a huge mistake.
It was, but it is really helping them out now... People see that the 390X is 10% faster than the reference 290X, and think because of that it is a faster card. But in reality, it is pretty damn close to an aftermarket 290X.
All this shows is just how good of a buy aftermarket 290 and 290x have been for the past year at $250 and $300 respectively. They came with equally good coolers and if you bought a model with Elpida RAM you could overclock it to exactly the same speed.
Really it shows what a mistake it was to release 290 and 290X to reviewers with that cooler. First time I have seen a card gain an enduring reputation as being slower than its direct competitor just because its cooler was not adequate.
Reviews still have been using those old reference launch 290x & 290 numbers. Now we see it here fully uncorked by a good cooler and reviewed as such. Imagine how poor the 980 reviews would of been if the 290x had released with such an adequate cooler. It would of been perf/w is great, but otherwise even with a new architecture it's still slower than 290x.
Yea, Hawaii is one of the best chips AMD has produced the last years and they screw up with this damn cooler.
290/X should have been released as 390/X series today with custom coolers with 4GB and 8GB models.
As of the R9 390/X price, GIVE US A BRAKE AMD. 2 years after Hawaii 290X and you are selling the same Chip with 8GB for the same price as in 2013 ???
I will not recommend the 390/X to anyone, better spend $100 more for GTX980 for higher perf AND lower power consumption,
or even better, wait for Fury Nano.
Yes, and IMO the reasoning behind that decision was to add value to their partner's cards. Reference cards were the models intended for DIYers that may want to add after market coolers, may have wanted to save a little money over after market cards, or maybe some don't care about a little extra noise. Noise isn't an issue for me, and there are sure to be others out there.
With FuryX, it seems AMD decided to take a different approach; build the best possible reference design at a higher price point than partner cards, then let their partners release non reference designs at lower price points and higher volume. My guess is that all Fury models will be non reference cards from their partners.
We'll see, but at any rate, the 390X seems to be very reasonably priced with better price/perf than their competition as usual.
It doesn't really add anything important - slightly faster stock clocks and more memory then you really need. Most of the target market for this card probably already have 290's, or 970's and they won't bother side grading - they'll wait for 14nm. Of the few that don't many will just pick up a 290 cheap, if you are going AMD because you love good value why would you pay more for the same card?
Dont know why AMD didnt offer this card immediately after 980 release. Sure would've dampened the 980 release and created a bigger splash imo.
Since November last year, the word from AIBs is this: "too much inventory of R280/X/290/X products", one theory is because someone didn't see the mining boom was a temporary thing, they ran out of stock everywhere and prices went crazy so they ordered a LOT more, then the mining crash...
The problem with rebrands is they don't really add anything. Most of the target market for this card probably already have 290's, or 970's and they won't bother side grading - they'll wait for 14nm. Of the few that don't many will just pick up a 290 cheap, if you are going AMD because you love good value why would you pay more for the same card?
Ofcource they will not get this card. Not even from 7970 or 680. But there is comming new buyers. 6970 and 580 and down users.
There is nothing wrong with rebrand refresh whatever. What matter is what you get as a consumer. Not names or tech but benefits.
And the only one getting hurt in the process was AMD, retailers made hay at the expense of (some) consumers & AMD, guess you can't plan for greed D:
Right on the money but it also shows how biased certain members on this forum have been all along since 290/290X series released that they would never acknowledge how much better an after-market 290/290X is. They are quick to criticize 390/390X cards now without giving an ounce of praise to the amazing price/performance of after-market 290/290X cards over the last 1.5 years by constantly calling them hot and loud. You can't have it both ways. The people who objectively didn't disregard 290/290X by recognizing that after-market cards were available all along can easily criticize the price/performance and higher prices of 390/390X but all those who ignored 290 cards are now being hypocritical since they are quick to compare after-market fire-sale 290/290X cards to 390/390X. 😎
Also, per Guru3D, their overclock is on the high side for most 290X cards. It sounds like the node has matured. Their 390X cards got 1200mhz on the core and 6600mhz on the memory (422GB/sec memory bandwidth!). The end result is 29% higher 3DMark score than a reference 290X and a whopping 32% higher than a 970! That's more than 2X higher than a GTX680.
index.php
For all those people screaming how Fury X needs to match 980Ti's 30% overclocking, I sure see no mention of 390X's overclocked performance being mentioned.
because they are not able to sell R9 2xx rebrands.If AMD cannot sell R9 2xx with such a cheap price than how can AMD sell rebrands with a higher price even if they add extra vram.
Because in the eyes of the Average Joe who ignored after-market cool and quiet 290X cards for the last 1.5 years because "first impressions are everything," he will now see a reference 290X in reviews against an after-market 390X. In overclocked states nearly 30% faster performance than a stock thermal throttling 290X.
It's only fair -- all those people who criticized 290/290X for being hot and loud now have no choice but to compare reference 290/290X to after-market 390/390X because using after-market 290/290X against 390/390X today would make their entire position over the last 1.5 years hypocritical. 😉
Exactly. The only review sites that have any right to use after-market 290/290X in 390/390X reviews are the ones who used after-market 290/290X in reviews all along. Any site that used a reference 290/290X for the last 1.5 years and ignored after-market 290/290X cards and now tries to mention how 390/390X are no better than 290/290X cards is most likely on NV's marketing payroll or is straight up biased. For brand agnostic users who always acknowledged after-market 290/290X cards, sure this release is very disappointing but I sure didn't see NV fans posting how amazing $220-240 after-market 290 and $270-300 after-market 290X have been all this time. In fact, they continued to discuss how 290 is hot and loud and requires a 750W PSU in defending a 960 2GB since January 2015.
They did -- it was called an after-market 290X. Welcome to 1.5 years ago.
Pretty remarkable how people were trolling for months how a ~300W card requires water-cooling and ignored how cool and quiet after-market 290/290X cards were:
This part is hilarious and shows how brand-attached the average PC gamer is when $240 after-market 290 and $280-300 290X cards still didn't sell:
390X = aka after-market 290X:
"Currently the R9 290X can easily be had for $330, so it seems to us given the age of the R9 290X and the fact that the R9 390X offers such a small performance bump, it should be introduced at or near this price. Sadly, however, the R9 390X carries an MSRP of $430, 30% more than the current R9 290X for less than 10% additional performance. This is still a better value than the GTX 980, costing 14% less for just 7% less performance, but it's hardly enough to get us excited."
LOL! Isn't that a familiar number. For months we've been saying how 290X is just 6-11% behind a 980 but oh boy people thought it was justifiable to pay $550 for that over a $280-300 after-market 290X.
390 = aka after-market 290
"This leaves us looking at the R9 390, which is a considerably better value at $330, making it a little over 20% cheaper and just 7% slower. The R9 390 roughly matches the performance of the R9 290X and it was 8% faster than the R9 290 while technically being faster than the GTX 970,"
Of note that both 390/390X are faster than 290/290X, which means these are refreshes, not re-brands -> essentially like 770 raised performance 8-10% over the 680, this is a repeat of that and no one called 770 a re-brand.
Still, goes to show how dead the GPU market has been in the mid-range space considering R9 290 was $399 as of late 2013. As Grooveriding alluded in the past, the most exciting cards this gen are 980Ti and Fury SKUs.
What I find absolutely amazing is the gushing some of these early reviews are doing for these cards.
Imagine, if these are almost 90% identical to the original cards launched with the biggest difference being the cooler.
"it's quiet"
"it uses less power"
"it runs cooler"
All characteristics tied to a good cooling setup. I tried to go back and pull some benchmarks from Cannuck's 290X Tri-X review but it seems they decided to use completely different setup, so I can't really make a good 1:1 comparison.
For example, in the few games that are available for both reviews
390X uses 8xMSAA 290X uses 4xMSAA
or
390X is pushed to 4K resolution while 290X stays at 1440p.
For power draw, what I really wanted to see in 290X they used 15min of Valley for 390X they used 15min of Hitman.
Overclock3D review has the MSI 390X tied with 980 which is quite surprising to be honest. I think 290X performance was understated due to the reference benchmarks from 2 years ago.
Imo also the good thing about 390x is it shows 970 and 980 is utterly uninteresting from a performance perspective. Damn all that hype those cards got for same as 290 perf...
