GTX480 arrived [evga forums]
badb0y
4,015
30
They also comment on the packaging, how it looks, etc. Stuff MOST people don't care for.
If you are going to care about heat and sound when buying a expensive card. Maybe you should reconsider the high end card game.. I can't even believe people are mentioning electric bills. lol
I've never once heard someone complain about such stuff in real life with computers.
You have never heard of anyone complain about heat or noise? Seems like your the one who needs to reconsider high end gaming cards...
You confuse infatuation with somebody giving you solid life advice.
No, no, that's your weak response to the rapage that MrK6 has bestowed upon you. I suggest you leave this thread and never return.
SlowSpyder
17,305
1,002
Seero, please reread what I said. I never once mentioned that Fermi being late had anything to do with it's architecture or was a knock against it. You said that it's drivers were early, I said that Nvidia has had working silicon for a while. Hence the drivers are likely to be very mature (relatively speaking for a launch part) since the driver team would have been working on them for quite a while. If the part was supposed to launch in October/November, and they've had working silicon and drivers since that time, if the part doesn't actually launch until April, then that would give them months to revise and tweak the drivers. Please reread what I wrote... all I said was that the drivers are likely more mature than you may think. I didn't say anything about Fermi being late... just that they had more time to make better drivers.
I didn't say that the Heaven bench was bias. I said that it's a synthetic benchmark and does things in a way that no game is likely to do them... mainly tessellation. Basing your opinion of an architecture being superior by a synthetic benchmark doesn't make sense to me...
Yes, it is the fastest single GPU card, no one denies that. That doesn't make it a superior architecture. Nvidia has known how fast the 5870 is since at least 9/09. Nvidia knew how fast Fermi had to be to beat the 5870, they did whatever they needed to do to acheive that. That doesn't make it a superior architecture. All it means in this case is that through brute force they pushed Fermi to be sure to make it faster than the 5870... Nvidia wasn't going to release a slower part. So to get it faster they had to push the power envelope creating a power sucking part that puts out tremendous heat compared to the competition. Think about it, a GTX480 uses a bit more power than a 5970 while being slower... hardly the sign of a 'superior' architecture. Can Nvidia even create a dual GPU Fermi based part to compete with the 5970? I have my doubts, this makes Fermi less dynamic than Cypress... again, hardly 'superior'.
I'm not being biased at all. AMD can afford to build the 5xxx parts from 'old' architecture because they made changes along the way. AMD was the first to use DDR5. AMD was way ahead of Nvidia in creating a 40nm part. AMD built GPU's that supported DX10.1 when Nvidia did not. AMD has built a tessellator into their hardware for years now. By AMD doing all of these things along the way they did not have to make the leap that Nvidia did. So what seems 'old' to you is the end product of making smaller changes more often. Nvidia is simply making a bigger change all at once. AMD did their homework.
I have absolutley no idea what you are saying in the last paragraph. But something for you to consider. The GTX480 uses somewhere around 530mm2 of silicon on the 40nm process. The 5970 uses somewhere around 660mm2 silicon on the 40nm process. Despite using more silicon ,running at a bit higher clock speed, and having a seperate pool of higher clocked DDR5 per GPU, the 5970 uses slightly less power. It uses less power and offers significantly more performance. Which architecture would appear to be 'superior'?
yh125d
6,886
Reviews are out, stated that 480 is the fastest single core card. Either they all lie or you simply don't wanna accept the fact.
I don't think anyone is refuting that directly
It is also a fact that 480 tends to use more electricity to get more performance out, but guess what, EVGA will have a Super super clock version out of 480. If putting more electricity into a chip means better perfermance, we may as well ramp up the voltage of old video card off ebay and call it a day. It simply don't work that way. There is a tolerance on how much juice the hardware can take. It can only take more juice if the card is designed to handle it. At the end, to push more resistors, more juices are needed. The challenge is, some parts may not handle the juice and fail to function. Again, 480 is not perfect, not where near perfect, but it is really okay given that it is first of its design. Now 5870 uses more electricity, louder, and hotter than 4870, but you don't have a problem with that. So why are you having problems that 480 is 2-5 dba louder, use 100 watt more, or produce more heat, about what a 100 watt lighbulb produces rock your boat is beyond me.
5870 vs 4870 uses maybe 50-60w more load power, but has better idle power, running temps, I think is actually quieter (4870 were mostly non-reference, and lots were loud), and gives 100% more performance
480 vs 5870 uses 100w more load, more idle, runs much hotter, considerably louder, but only nets ~15% more performance. It's far from an equal comparison
yh125d
6,886
You must not talk to many people though. I just two weeks ago installed a quieter PSU for my brother, as well as a better GPU cooler and CPU HSF cause they were running in the 60s which he didn't really like, and he doesn't know jack about computers.
My coworkers complain all the time about how our lenovos are too loud. My mother has a noisy dell. My aunt has a hot running laptop
If enthusiasts who buy expensive cards dont care about heat and noise, why is there such a large aftermarket for third party coolers?
You dont care about heat or noise or power, and that's fine - but you have to realize you are very much in the minority
OCGuy
27,224
37
Most of the people commenting on things such as power/noise are probably not in the high-end market anyway.
thilanliyan
12,062
2,275
The bigger complaints are about the heat and keeping the card cool (and hopefully quiet). I know for sure that there is no way my current watercooling loop could handle the heat of a GTX480 and my OCed Phenom with the low speed fans I'm using. I like my computer fairly silent and that would not be easy to achieve with my setup if I went for a GTX480/GTX470 compared to a 5870/5850. I myself would definitely trade some performance for cooler and quieter...but that's just me.
Blue Shift
272
Although most of this has been said over the course of various rants, my 2c:
The 480 is a nice card for what it represents, but the implementation rather sucks for gamers. The performance increase is NOT what you'd expect for a part priced $100 higher than the 5870, so using it purely for standard gaming purposes isn't the most economical of strategies. That being said, the 480 is certainly a nice fit for users that want to take advantage of its general-purpose computing features or 3dVision.
The 470, while seemingly priced at a nice spot between the 5850 and 5870, isn't as good a value proposition as nV and some reviewers would make one think. Paying $25 extra per year in power costs makes the thing as expensive as a 5870 after two years, so they should be viewed as competing at the same price point... And the 470, if you'll look at the numbers, doesn't quite have what it takes to challenge the 5870 at $400.
If these things turn out to have mucho overclockability, then maybe my opinion will change...
Seero
1,456
Specification is the number one thing when it comes to algorithm or coding, then comes the testing. While they may few a few working fermi back then, it is really not enough to execute driver testing. There are a lot going on from there to here and the TMSC shortage seriously slow down the process. It took 10.3 to arrive 6 months after cypress is released, and they probably have cypress 6 months before release. Again, Unigine wasn't there 1 year ago, so 5870 faced the edge of Dx11, but it pull through. Nvidia on the other hand can test their optimized code with unigine, allowing them to build a better driver under Dx11. Having said that, the 10.3 development have better advantage as they have both hardware/software tools. If we use cata 10 to do comparisons, then 480 will beat 5870 by 30%.
Don't let Charlie's word get into you. If brute force works, then we don't need new hardwares. If you OC, then you know there are lots of boundaries that you can't break beyond heat. The card is design to take that much juice, not brute force as it won't work. Again, forcing 400 watts into your 5870 will fry it, that is all.
5970, 4970, 295, and 275 are more or less xfire/sli in one card. Unless SLI don't work on 480, otherwise making a dual GPU part is not a problem. now 1000 CUDA cores in total will beat 5970, but uses a lot more electricity, but what about 800 CUDA cores? 700? Say 768 CUDA cores will beat 5970, then each card only needs 384 CUDA cores. Well if they can make 480 CUDA core in one card, 384 is not a problem. In fact, increase yield too. What is the optimal number of cores for their first dual GPU can not be determined in these type of debate, but must be done by their Engineers in Lab. I really don't know, but I will say it is very doable.
Don't let the word "old" bothers you. We care if it works, not if it is new. If ATI can keep recycle the old design by making it smaller, yet keep being competitive down the road, then it is a good design as they will save lots of money on test, design, and test on new design. In fact, the 4xxx design was engineered to support DirectX10, where 2xx isn't, shrinking it make sense for ATI and the result is not bad at all.
By Superior, I referred it compare to 2xx, not cypress. Now we can argue until the end of time between 2xx design vs 4xxx design, but ATI proved that there are room for a shrink version of the 4xxx design. Nv may have agreed with that and save the 3xx series for a 2xx shrink, I don't know. I do know however, that the Fermi design work as good as if 2xx design were shrinked on Dx9/10, but wins by a lot on Dx11 plus some CUDA applications. Other than tessellation, ATI can't be compare to Nv ATM as they don't have the same common ground.
All I am saying is, brute force won't work on hardwares. 480 uses more electricity because it was design to do so. Yes you may argue that 5970 uses less electricity, but 480 beats 5970 on tessellation. It is a pro and con situation. 4870 handle most games on max and you won't see differences with 5870, simply because 4870 delivers 50+ FPS already. In those cases, the extra electricity used by 5870 is wasted. Will you then call 5870 inefficient compare to 4870?
