GTX 6xx failure rate (poll)
Have you had to RMA a GTX 6xx card?
  • GTX 690 no problems
  • GTX 690, had to RMA a card
  • GTX 680 no problems
  • GTX 680, had to RMA a card
  • GTX 670 no problems
  • GTX 670, had to RMA a card
  • GTX 660 no problems
  • GTX 660, had to RMA a card
cmdrdredd
27,052
357
I want to be clear, I did have to RMA a card but it was one of the first gen EVGA GTX 670 SC cards that were part of the faulty batch. I had it replaced with a FTW model and all has been well since then.
biostud
20,097
7,198
It does seem that some of the early GTX 670 with factory overclocks has a higher failure rate than normal.
Ed1
453
18
I bought a MSI 660ti PE and there was problem with booting the new system , no display. The PCB was curved , if that mattered .
New one is running fine now .
Granseth
258
If there was a common issue, I am sure you could see it here.
http://www.hardware.fr/articles/881-5/cartes-graphiques.html
Interesting, though not surprising that the higher grade cards (7970/580) have a higher fault rate than the mainstream cards.
But a vote like this will probably give the wrong results as those who had to RMA a card is more likely to vote than those who have a functioning card. And that is before anyone finds a good reason to sabotage the results.
AnandThenMan
3,991
627
I remember a few years ago seeing charts that showed video card failure rates anywhere from 2-10% depending on the GPU, model and vendor. I wonder what the stats would look like today.
