System Specifications:
I. Processor/CPU:
i7 3770k
II. Current Graphics Card:
That's what I need you guys for!
III. Display Resolution:
Will be explained below
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age). If possible, please provide a link to a website containing the power supply specifications:
Looking at Corsair Enthusiast 850W 80 PLUS Bronze Certified ATX12V / EPS12V, willing to get a better one
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent):
nzxt phantom 820 is what I'm looking at, willing to switch.
Purchase Details:
I. Budget? Please be sure to include currency (If not USD), retailer preferences & specify whether rebates are a viable option.
$600 USD (flexible)
II. Any particular preferences (Manufacturer[nV or AMD], Brand[XFX, Sapphire, EVGA, etc], Cooling Solutions)?
No preferences, but I'm liquid cooling the GPU
III. Do you plan to have any Multi-GPU solutions such as Crossfire or SLI?
Not unless you guys think I need to!
IV. Have you previously looked at a product(s) which you feel would fit your needs?
I think both the GTX 680 and Radeon 7970 are solid cards, i just need to know what one is better!
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
I'm looking to multibox World of Warcraft, running at least 25 copies. The resolution of each window isn't particularly high, but there will be a ton of them.
VI. Do you plan on overclocking the card you intend to purchase?
I'm liquid cooling it, so I'd say overclocking is a definite possibility.
Long story:
I have seen numerous benchmarks and performance comparisons of the two cards, but they are for top of the line games at top highest settings.
I on the other hand, am looking for a card that will best let me multi-box world of warcraft. I'm looking to be able to run 25 (or more) copies at the same time, so I can raid enemy cities by myself.
Do you guys think one of these cards is better than the other for this? I was thinking maybe the Radeon because it has more vram and higher memory bandwidth, but the GTX 480 is also sold in a 4gb form.
Price isn't really a problem, so you can ignore the price difference, i just want to know which you guys think will be better. I'd also appreciate if you could explain why you think one is better, i'm trying to learn more about this kind of thing and any information would be appreciated!
I. Processor/CPU:
i7 3770k
Purchase Details:
$600 USD (flexible)
Long story:
