GTX 670 OC'd to GTX 680 specs???
Fx1
1,215
30 minutes isn't even enough for a stress test to determine the overclock is stable, never mind fine tuning it
What absolute BS. Not everyone wants to spend time overclocking when they could spend time gaming.
It took me 20 seconds to move a slider to 1125mhz from 1000 mhz on a GPU that amd made for 925mhz.
lehtv
11,897
74
That didn't involve stress testing to determine it's stable, and neither did it involve any fine tuning which means finding optimal core clock, memory clock (and if applicable, voltage).
poohbear
2,284
He didn't say it was a 50% boost from 40 to 60, he said it stops frequent drops to 40 fps. It might shock you to know that some 7950s are capable of going from 800MHz to 1250 + MHz. That is more than a 50% overclock, so it is possible.
Yes its very shocking actually, and absolutely an exception to the rule. The vast majority of video cards do NOT overclock that well, so i never bothered caring. This is especially true in the high end where there's already little headroom to overclock because they're at their limit.(no high end card is gonna overclock 50%, thats for sure!)
CPUs have always overclocked 30%-50% atleast, & its hardly an exception, every mid tier cpu overclocks that well.
Anyways all the power to u guys if ure seeing a 50% increase in performance from ur overclocks. I doubt my gtx 670 windforce OC can get anywhere near a 50% overclock as its already @ the top of the food chain.
Fx1
1,215
who stress tests a GPU?
Turn on BF3 and play for 3 hours without a crash on Ultra and you know your stable.
lehtv
11,897
74
It took you 3 hours to determine the OC is stable? Correct me if I'm wrong but I think 3 hours is more than 30 minutes.
MrK6
4,458
4
Like I said, if you understood how hardware functioned, it would only take 30 minutes. Since you don't, it takes you longer. Try not to place your limitations on others.
Fx1
1,215
Those 3 hours are my gaming hours. Its not a "waste" basically just clock and play
Rvenger
Elite Member <br> Super Moderator <br> Video Cards
Apr 6, 2004
6,283
1. Move slider to right, play games.
2. If/When driver crash occurs, move said slider slowly towards the left until stable operation
3. Enjoy :thumbsup:
ICDP
707
Yes its very shocking actually, and absolutely an exception to the rule. The vast majority of video cards do NOT overclock that well, so i never bothered caring. This is especially true in the high end where there's already little headroom to overclock because they're at their limit.(no high end card is gonna overclock 50%, thats for sure!).
I do agree with your ealier post that the new Radeons are the exception when taken in context of GPU history. Though it absolutely is not an execption to the rule for 7950s so clock so well, 40%-50% is very achievable.
