GTX 465 review ... one more shoe from NV drops
197.75 WHQL for Nvidia GeForce used = fail.
New drivers or possibly the 256 beta's released (for the gtx series) yesterday could have helped.
Why would Nvidia let them break the NDA? Think about it.
Who says they signed an NDA?
With the GTX470/480 their review was out a while after the official launch, so it's entirely possible that there was no NDA to break.
Those numbers look really low. 59FPS for a 5870 in DIRt2 at 1920x1080, its usually in the high 60s for the or low 70s in other reviews
EDIT: Just checked anandtech's reviews of the OC'd 5870s. the 5850 gets 62FPS at 1920x1200 vs 51FPS at 1920x1080. Will have to wait for other reviews I guess
Did it explode yet. 😛
Nope, but I am thinking of clocking it back down some for now. However, I am trying to sell the 4870x2 and put in a 5850 instead. I like having the option of a backup machine I can game on or to take to a lan party. Still, basically being used as an HTPC right now. You can see pictures of it in my for sale thread.
Those numbers look really low. 59FPS for a 5870 at 1920x1080, its usually in the high 60s for the or low 70s in other reviews
Comparing across review sites is never the best idea.
Unfortunately since it's only a preview it misses a lot, especially when it comes to comparisons with other cards (things like the HD5830, HD5770 and HD5770 Crossfire, and maybe some lower end SLI setups) would be nice. HD5770 1GB is about the same $300 as an HD5850.
One important thing to consider is that it's not always as bad as it looks, as I already noted.
While it gets soundly beaten by the HD5850 at 2560x1600, at lower resolutions it competes without too much issue for the most part, and given that it's (arguably) overpriced at $280, when the price (hopefully) becomes more reasonable, then for a medium end user (i.e. 20~22" monitor), it might not actually be that bad (especially at somewhere around $250), since an extra $50 for an HD5850 won't get you much at 16x10/9, if anything.
The further down you go, the less you need to realistically look at higher end resolutions, because this sort of solution, or the HD5830 or HD5770 aren't as likely to be used at the higher end.
for a $280 card, I think its pretty fair to look at 1920x1080. a 5770 which is almost half the price, 1600x1050 is more reasonable.
How do you go from a 279 card to a 699 card in your evaluation process?
Because originally it was going to be a 5770. Then I figured with the 128-bit bus....I could go 5770 Crossfire. But then what is the point in that when I could just get the 5870 and not have possible Crossfire issues ?
Which brings up the 5870 competition, the GTX470. When then I read it may be canceled in favor of a GTX465 "I think".
Which then I figured since I will be upgrading, why not say to hell with it and get a top tier card. 5970 / GTX 490 to last a lot longer.
So yea, it may not make much sense, but oh well. Top tier it is.
What are you asking for the 4870X2 ? Would go great in my wifes pc.
Fermi...HTPC??!!
*head explodes* (much like people's HTPCs would explode with Fermi in it)
I'm always looking for options (though not I said like hell it'll happen, at least not on a GF100 chip). I'm throwing my current rig in an SG05 come next week, all on a 300W SFX PSU 🙂, so anything with a great "bang-for-your-watt" factor gets my inspection :thumbsup:.
I do not understand the reasoning behind someone saying that a card is meant for a specific resolution. Everyone told me when I purchased my GTX 280 that it was 'overkill' for my resolution (1680x1050) and would be a complete waste. I don't really feel that way... I mean, I love AA, AF and Transparency SS. All of those put a heavier load on the ROPs than running 2560x1600 with no AA.
I guess if people don't like buttery smooth FPS, AA, AF, then maybe a card like that would have been a waste - But last I checked, we buy fast graphics cards to turn up the eye candy, right? Or do people buy a 480 GTX to just set the game to 'minimum' and play away? Seriously?
As it stands now, I don't believe a 5870 or a 480 GTX is overkill for my resolution and I could make good use it, bringing it to it's knees with some eye candy and filtering settings turned up high enough. Not to mention that 'tomorrows' games will run great, and today's games can run stellar with some super high settings. To each their own, I guess.
as long as the rest of a system is up to snuff then theres nothing wrong with getting the fastest card you can afford. at the same time I would rather have a larger 1920x1080/1200 monitor then having a smaller res and turning up the AA.
NV has just totaly screwed up this generation of GPU's, completely dropped the ball. Which pisses me off because there will be no price wars now.
Ahhh, nvidia's very own 5830...only it seems even worse.
And the "well it's good at lower resolutions" thing doesn't fly, sorry. If you are using low rez with an expensive card, you're going to want to be able to crank the AA way way up, or use super sampling if possible, etc...
This would be a fantastic card at $199. But the price point is just all wrong. Who knows, maybe some will be unlockable to a 470 or something?
even at $199 it would be a shitty upgrade for anybody with decent last gen card as its no faster than a gtx275.
275 GTX @ 55nm vs 465 GTX @ 40nm: Which one has more heat/energy usage per FPS?
Could 40nm actually be worse than 55nm in this case?
What resolution do you play at? Since when has 1080p been considered low resolution?
Most of the tests in the review are run with AA/AF.
In some it does compete at 1920x1080 (and below) even with an HD5850.
Specifically in Mass Effect 2 it's a better buy than the HD5850 for 1600x900 and equal at 1920x1080. Same story in Dirt 2 at those resolutions (and for Dirt 2 the GTX275 can be discounted since it's running a different codepath).
In Crysis and Resident Evil 5 it is pretty horrible at all resolutions compared to both the GTX275 and HD5850 given its price point, but as you say, at a cheaper price it might be quite nice.
And considering the tests were run with high AA/AF, that's already taken into consideration when using this review.
It is overpriced a bit, but it's not all that far off in many cases (although not all) to something like the HD5850 at the resolutions it's likely to be used for.
A $200~$250 pricepoint would make it a lot more appealing though, so it is still a bit too expensive.
Who on earth buys a card at this price point and doesn't expect to use AA and AF in spadefuls? Particularly so since most of those framerates are relatively playable 😉 I haven't turned AF off in years and don't intend to start now 🙂
On the very limited information we have (big factors being power and noise, they don't sound too complimentary on the latter, however it is a prerelease model), I don't think it is unreasonable to say that it's pretty uninspiring value compared to the 5850, (and probably the 5830, and even more probably the 5770, if you judge value as a cost/fps).
For comparison's sake a simple comparison of average fps at your chosen comparison resolution of Full HD gives you the following breakdown:
Cost
Cheapest newegg 5850s are $289, MRSP on the GTX 465 is $279, so it is 1% cheaper on a theoretical pricing comparison (since you can't actually buy one yet I don't think?)
Gaming
Crysis Warhead: 22% slower
RE5: 40% slower
ME2: 2% faster
Dirt2: 13% faster
Battleforge: 9% slower
Average: 11.2% slower
Assuming my maths is right (never taken as given!), you have to squint pretty hard to suggest it's anything like a sensible deal unless you particularly and specifically play Dirt2, especially if that picture holds accross a broader selection of games when we get full reviews (it might not, but it might).
Hopefully retail pricing will be lower 🙂
They are probably within 20w of each other, so it's like I said. 4890 performance a year later for $100 more with the same power usage
