Wreckage
Banned
Originally posted by: dguy6789
See I can do it too.
:roll:
Seems Rollo was the lesser of evils here.
Originally posted by: chizow
GTX 260 and 4870 1GB are pretty much a toss-up, I'd give the edge though to the GTX 260 for better cooling, overclockability, driver support for new games and warranty. If you don't want to overclock yourself, board-partner selection becomes even more important factor in Nvidia's favor, with much better factory overclocked choices.
Oh, and the GTX 260 also beats the 4870X2 at times (since apparently the exception is now the rule around here)! 🙂
Originally posted by: LOUISSSSS
+1 for 4870 1gb, better drivers, physx is useless, better performance/$$. 260 cannot compete with the 280 in any games, the 4870 can beat the 280 in some games and costs a lot less.
make yourself feel better and get the 4870 like most in here are telling you to.
The 4870 was faster before those new nvidia drivers came out too.
What was the point of "the gtx260 216sp was actually faster with one set of drivers a few months ago and then ATI countered with their own better drivers and made it a total wash again." ?
Originally posted by: Wreckage
Either way, I already linked to 3 recent reviews that give the edge to the GTX260.
Plus the 260 runs cooler, has more features and better image quality.
Again you don't have to take my word for it you can read the 3 reviews I linked.
Originally posted by: jaredpace
If you know how to increase the volts to the gpu, the 260 overclocks by a greater margin yielding better performance.
It's a close call... If you can find either for around $195 currently, then they are both great choices. I chose the 260 65nm 192 shader. I would choose BFG or EVGA brand, for better workmanship & quality. The 216 has the 9th cluster active, making overclocking slightly more difficult generating more heat. I've seen the 575mhz core as high as 860mhz on the stock cooler/shroud, shaders as high as 1600~1700 and memory as high as 2650. These are like massive 30%OC's putting this card's performance comfortably and consistenly between a gtx280 and gtx295. That is something an oc'd 48701GB can only do in a few situations, like assasin's creed, grid, or ultra high res /AA gaming.
It's potential is greater than the 280 when overvolting because of the less heat, and less active silicon (although having less shaders is a slight disadvantage). the 448bit bus/ 8xxmb of ram is something you can live with for $190. The 65nm 260 also has the Volterra VRM (same as 280's, 4870/x2, gtx295, and 9800gx2's. You can easily feed this card 1.3 vgpu via software - resulting in a comfortable 200mhz OC on the core. It already has the same memory as the original 280s, and is running at only 999mhz - often times ocing 300mhz easy.
260 gets my vote for those reasons. If only it could be found for ~ $150.
Edit:
I would have chosen the newer 55nm 260, if they had not skimped out on the voltage regulators, silicon, and cooling solution to cut costs.
here is an old 65nm at 820 / 1300 / 1600
http://img.techpowerup.org/080801/bios.jpg
Here is how to pump more than 1.12v or 1.18v into the 260 (or a 4870) without having to solder:
http://www.xtremesystems.org/f...howthread.php?t=215521
LOL
btw...i dont think you can go wronq with either card, because they are both excellent choices, but you should definitely consider what is available right at this moment, not some unproven mumbojumbo that COULD sometime, maybe, make a difference...by then, a whole new set of nextgen cards will be out 🙂
Originally posted by: evolucion8
Don't listen to Wreckage's facts with all the links he provided. Listen to my skewed opinion
We weren't expecting it, but the Nvidia BFG GTX-260 Core 216 (MaxCore) made it a clean sweep. With every game at every resolution, it took the lead and kept it. If this were a Shootout at the OK Corral the ATI GPU would be sprawled in a pool of blood with five holes in its core and the Nvidia GPU would be left standing unscathed.
So now a 4870 surpasses a 280 :roll:
As noted I already showed reviews from 3 different sites that have the 260 in the lead (with the 280 far ahead of that even).
Here's another one that pretty much seals the deal.
http://www.bjorn3d.com/read.php?cID=1414&pageID=5839
Yeah, that heavily overclocked Core 216 is faster than the stock Radeon 4870......
That GTX260 is over $300 still, the HD4870 1GB is closer to $230.
