- Oct 20, 2014
- 8,796
- 7,423
- 136
Figured it was probably more appropriate to post this question here instead of in the Displays subforum since my problem seems to be with GSync and not the panel. I'm trying to setup GSync between my GTX 1660 Super and my Asus TUF Gaming VG289Q1A, which is a 4k 60Hz FreeSync panel, with the 1660S connected via DisplayPort. I had it working perfectly before but did a reinstall of Windows 10 after getting a new cpu and board and now don't have it right.
In Settings->Display->Advanced Display Settings my monitor always wants to run at 59.97Hz instead of 60Hz so I leave the refresh rate at 59.97Hz.
In Settings->Display->Graphics Settings I have Variable refresh rate set to On.
In Nvidia Control Panel->Manage 3D Settings I have
I have to put a Framerate limiter because otherwise GSync will just let the gpu run up to 144 fps output won't it? Since GSync panels are supposed to support 144 Hz?
- Max Frame Rate: 59
- Monitor Technology: G-Sync Compatible
- Vertical Sync: Off
