Originally posted by: KRandor
Noooo - O.k. so a lot of this was my fault for not explaining myself properly - (sorry!). Right then... What I really meant to say about mass and energy usage etc. is that the forms of energy it will be made up of at EVERY level - will be in CONSTANT motion - (in fact I expect that to be the case for the entire universe). The fact that gravity is a system of CONSTANT ACCELERATION means that an object HAS to be using energy constantly, no matter which direction gravity is travelling in...
Constant acceleration is a classical explanation. It is the same as with electrons orbiting atomic nuclei. For the longest time, people wondered why electrons do not eventually spiral and crash into the nucleus of the atom. This is where General Relativity broke down and Quantum Mechanics took over.
Now, the question becomes, what is the difference between a planet orbiting a sun as opposed to an imbalanced baton twirling in a vacuum? Answer that with your theory.
(and no, I do not mean state the obvious. Explain the behavior)
Like I also said, gravity will be part of an energy transfer CYCLE - whichever direction it is working in - there will be a corresponding amount of energy (in whatever form(s)) travelling in the opposite direction. The problem there, is that they will probably be as efficient as gravity, and if they do NOT affect anything that we can detect (unlike gravity) then it/they will be hard to discover... The 'fact' is that an object is obviously using energy - I just put a theory of HOW, forward - if you don't like it, then invent one of your own...;-)
I have no need to. Others with greater intelligences than ours have done the work for me. An object doesn't 'use' energy; It
is energy.
What you are proposing is anti-gravity, which is also under speculation. Also, if it does not affect anything that we can detect (like gravity) then it cannot be part of this "transfer cycle" because it would not affect any point of the transfer cycle in the first place. This would mean it is not part of the transfer cycle. If anything affects anything else, it can be detected. If there exists something which cannot be detected, then it does not exist. (see below)
and P.S. it's obvious that gravity does not need 'two' objects in order to work - it only needs one, and dosen't have to operate 'between' two objects - it's just that that is the only way we know that it exists... (I.e. it affects the entire surrounding area of an object, whether there is another object there to act upon or not...).
Incorrect. Gravity requires two objects to work. It's like saying a light bulb will illuminate a room whether or not anyone is there to see it. Reference Schroedinger's cat or Heisenberg's Uncertainty Principle if you're lost.
Actually, for 'black holes' to exist then gravity MUST be able to travel faster than c... SInce that is what causes the black hole in the first place...
I thought we already agreed that 'black holes' are formed when an object is constricted to a size smaller than its <FONT size=1>Shwarzchild radius. That statement is independent of the speed of gravity or anything else, for that matter.</FONT>
Oh and don't try and put like this book did - (I think it was A Brief History Of Time - Dr Steven Hawking) - where gravity works fine until it reaches c - then look, it magically stops accelerating for the rest of the way 'down'...:-/ If gavity accelerates stuff then it will do it ALL the way down, just like all the evidence suggests, and since it's more efficient (and works at a much lower level) than light - (even physicists agree with me on THAT one) - there should be no reason WHY it couldn't possibly travel faster... It's simple - if black holes exist, then gravity CAN exceed c - and if they don't then we don't know if it can or can't...
I'm assuming you're saying that gravity is strong enough to prevent light from escaping the event horizon. That, in and by itself, is not sufficient evidence to support the idea that gravity propogates faster than light. If such a simple phenomenon were capable of providing enough basis to support it, we wouldn't be here arguing over it in the first place.
I think we're getting some wires crossed around here somewhere....:-/ Like I said, the overall amount of energy used by objects of equal mass / transferred by their gravitational fields WILL BE EQUAL. (E=E). The problem here, (for you), is that gravity is a force, which accelerates everything we know of in an area surrounding an object. What I am saying is that if the amount of AREA over which the force operates is different then it's RATE OF ACCELERATION WILL BE DIFFERENT in direct proportion in order for the total amount of energy transferred to be the same... And since the strength of gravity is defined by it's rate of acceleration, then the field STRENGTH will therefore be different...
Two things.
1. I'm not having any problem in dealing with gravity as a force. It's much simpler at my limited knowledge level to contemplate with classical concepts.
2. Your idea is this : The reason why gravity is directly proportional to the inverse square of the distance away from the source is similar to electrical fields : the total field strength, if measured with any type of enclosure around the source, is constant.
I haven't argued against that. In fact, I've been trying to argue that this is how things are. From what I am reading, you're the one having a problem accepting that the total field strength is constant.
The definition of energy I have been using does not mention the word 'matter' (or 'mass') at all... (And neither did 'work' for that 'matter'). In fact as we 'burrow' deeper into the working of the universe, I expect the term 'energy' to still be used, since it does still work... Energy and work are a couple of terms which CAN be used universally due to their definitions, and in fact it may not be such a bad thing...
Any word in the English language can be used universally. In fact, any word in
any language can be used universally. Unfortunately, due to the limitations of language and the internet, it would be nice to use the dictionary definition as opposed to reassigning words to random concepts; it's not helping your case.
If you're referring to the use of energy to define the universe, then this is nothing new. The concept of forces has met a similar demise, being now relegated to introductary level physics. Energy is, as far as I know, the more widely used basis for mid-level physics and beyond.
If gravitons are 'emitted' (as per current 'thought')
Actually, no, current "thought" would probably be closer to a field or a bend in spacetime, depending on who you ask. Gravitons are currently considered flights of fancy.
- then energy has to be being transferred away from an object... Unfortunately, if that were the case, then gravity would have to be fairly inefficient to have the effects we see
And here I was, thinking you were trying to say that gravity is
very "efficient." If what we see (and that includes black holes) requires it to be "fairly inefficient"...
(which is also why we have some of the current stuff like: The reason every object falls at the same speed is that they resist the movement in proportion to their mass - which if it were the case then the gravitational field beyond the object would also be affected (i.e. some energy would be absorbed by the object and not transferred onto whatever's above it) (and it's not affected) - (consistency in direction and rate, remember)) - which is something that it is not - (and like I said even physicists admit that gravity is VERY efficient).
Yet, the gravitational field beyond the object
is affected. One has merely to view the stars in the sky as an object passes close. That type of activity was used to verify Special Relativity and is routinely used to detect black holes (which are technically thereotical).
The problem with gravity and the 'messenger particle' stuff is that at the level it works at, particles probably don't exist as such, and it's not just working btween 'objects' - it's obviously working on things we have no knowledge of atm...
Once again, what you do not know can't hurt you. Similar idea in that what you have no knowledge of cannot exist. Once it is detected, it is known, and therefore, exists. Reference above if you're confused.
I know that me calling 'consistency in direction and rate of transfer' Efficiency wasn't really in line with it's current definition, but I didn't know what else to call it...:-/ If you have any suggestions, please let me know...
Try 'inertia', as defined in Newtonian Physics. And it really has almost nothing to do with why the use of gravitons is inappropriate for any model.
The reason why gravity should not use a 'graviton' is that it has NO properties that can be associated with a particle AT ALL - It works at too low a level for that... - (Unlike EM radiation/matter etc...). Using 'waves' on the other hand should work... (I think).
Try strings.
There does seem to be a growing number who believe in string theory, which is probably more along the lines of a fledgling Theory than a flight of fancy.
Oh, wait, unfortunately, string theory allows for the existence of gravitons.
Let me ask you this :
How do you measure space?
Answer: With a ruler.
Now ask, what happens if the ruler changes shape?
Once you've answered that, think about what happens if gravity actually propogates in the same manner as light.
It's an interesting exercise, although derived from nothing more then idle thought.
