Grass Fed Beef and CLA content...
IGBT
I've been eating Grass Fed Beef for awhile...even tried Grass Fed Bison. The meat is indeed leaner and has a tasty flavor. The Bison ham burger fashioned into a meatloaf was especially good. Any thoughts on Grass Fed Beef and it's higher CLA content due to Grass Fed??
Higher CLA means more Omega-6, which is generally already overly high in Americans' diet. The human body needs a proper ratio of omega6 to omega3 to optimally process them into EPA and DHA in the body. A tool like cronometer where you log your meals, can help you identify where you are deficient in Omega 3 to help hit that optimal balance.
Otherwise, you can just take preformed EPA/DHA supplements.
[/QAre the supplements really the same as naturally occurring CLA and aren't Grass Fed Cattle healthier (no anti biotics).. because they are eating something much closer to what they evolved on i.e. their wild ancestors didn't eat grains but grazed on wild grass and other wild grass like vegetation??
Grass fed beef is likely better in more regards than one. Since they eat "greens", they thus have a higher intake of vitamin K1, which then gets converted into K2. This vitamin is part of a system of calcium deposition, with K2 activating the enzymes that put the calcium in appropriate places. Prior to the knowledge, medical pros added to their kill count by prescribing calcium and vitamin D supplements without K2 increase for older people, this wound up with the calcium being deposited in their arteries.
The evidence seems to indicate that conjugated form may be beneficial to animals, and not quite clear on humans. Nothing seems to indicate harm and perhaps a slight decrease in obesity. This chemical, due to shape, differs from normal linoleic acid. This is idenfitied by the nomenclature adding conjugated to the term.
With red meat, the matter of heme intake does matter a bit. The solution seems to be a simple pragmatic one. Eat some berries or other polyphenol-based product along with vitamin C to stop it from reacting in a damaging manner to colon cells. As if by instinct, humans often do adulterate beef with tomato products to enhance pleasure of beef during consumption. And absolutely do not cook and consume red meat with most other polyunsaturated fats aside from what is already inside of it(so don't eat veggie oil fried beef, which is essentially all restaurant beef).
Adulteration with calcium containing or cholrophyll containing foods would also be prudent for the same reasons. Cheese, green vegetables.
The omega-6:3 ratio is much better in grass-fed beef as well. Thus, even if CLA is harmful, the ratio is superior to that of grain fed beef and certainly better than consuming a raw supplement.
CLAs derived from supplement apparently are a different occurring acid than the ones that occur in natural animals. Never mind that pressing and the refine the oil does involve the use of compounds like hexane.
Throw in some sardines to broaden the net of micros and have an easy source of DHA/EPA. Alpha-linolenic acid can be converted to DHA and EPA but the process is inefficient. The beef is one source but fatty fish like sardines are a bounty, although with other vitamins and minerals.
Be sure the meat is clearly grass-fed and not just organic.
Keep on eating the grass-fed beef if your budget can accommodate it, but venturing out can be beneficial as well. Elk eating could arguably be more healthy since "elk farms" are essentially forests and the goes to having the landowner keep it as a forest.
(I flunked out of college organic chemistry due to laziness but some things never stop sticking...nomenclature matters with chemicals)
