The Godfather
Thanks.
Originally posted by: SparkyJJO
I got my ti-89 titanium brand new off ebay for $127 shipped. Higher than what you want, but it is a nice calculator which will last you a long time
I got my 89Ti for $100 shipped. It arrived in perfect condition.
When I was in HS and College they allowed anything that wasn't QWERTY (i.e. TI-92), so anything up to and including the TI-89 was fair game.Originally posted by: SarcasticDwarf
Do note though that many lower level college classes (and most HS classes) will not allow anything over a TI-84 as they will basiocally solve the entire problem for you.Originally posted by: Tu13erhead
I had a TI-83+ throughout high school, now I use a TI-89 Titanium for college classes. I kind of wish I'd just bought the TI-89 in the first place to save me some $$.
HP and Casio both make graphing calculators. However, the HP calculators are obscenely expensive.Originally posted by: SarcasticDwarf
Most of it is simply because TI is the only company out there that makes them.Originally posted by: killershroom1985
Never understood why those things cost so much. Old technology
If you can't figure out how to put the equation into a different calculator than the example, you should fail the class automatically.Originally posted by: SarcasticDwarf
Yes, other companies *make them*, but TI is the standard. If you have another brand calc and the prof is explaining how to do something, you will not have a clue as the interface is different.
Well, if he ends up taking the SAT, the TI-89 will not be allowed, either. You don't want to bring one of those and end up without a calculator to use on the test. Therefore, he should probably buy a TI-83 or TI-84.Originally posted by: Zenmervolt
ZV
ZV
ZV
You don't need a graphing calc on the SAT.
Originally posted by: bonkers325
the only reason graphing calculators are used in high school is to familiarize students with them. i havent used any of the advanced functions since AP calculus. in fact, the only reason i would use a TI-xx is because of the large screen (you can see whatever it is you're inputting)
Originally posted by: KevinF
The Godfather -- yes, the Ti-89 will solve variable or symbolic equations for you. It also works natively with fractions, radicals, and imaginary numbers.
It also displays everything you enter like it should look -- the so called pretty print feature, which makes it a lot easier to make sure what you entered is correct. It does symbolic integration and differentiation, which is a big deal once you get to calculus. It will also do unit conversion, which can be a big help in chemistry and physics.
