Harry_Wild
:integrated GPU can do 4k resolution @60Hz through displayport. Again, if all you are doing is normal web surfing and video watching, you do not need a lot of cpu or gpu power. It doesn't matter how old the computer equipment is if that is all you are doing.
Can you give me further info on the integrated GPU can do 4K resolution @60HZ through displayport.
My PC that is coming has an Intel i7 4790 CPU. It is a Thinkstation p300 SFF desktop with 8GB.
What do I need to hook it up? Display port 1.2 is that a cable or a port itself?
What do I need to setup in bios or Windows 8.1 to make it work?
Thanks for the info!
P.S.:
I read a couple of articles that are dated 2012-2013 at the HD 4600 Graphic in 5th generation i7! The last article dated February 2013 talked about Intel possibly fixing the 4600 firmware so you do not have to connect two HDMI together to power up to reach 3840x2160.
I read about the proposal future Display port 1.2 but the current display port back then was 1.1 and it could not connect to get better then 2K!
Now I trying now to find info on the display port 1.2 - it can do 4K but not how set it up from display port output in the PC to the monitor in Windows 8.1! No articles at all; leading me to believe it is automatically done????
My hardware is coming but I try to get ahead of the curve on this. I have a Thinkstation p300 SFF 8GB.
My new monitor also shipping is a 24" Dell P2415Q - it a UHD monitor - about 3800 x 2160!
???? Confused!
