Originally posted by: Clocker
people on these boards need to chill
too much attitude
lets say it was a misunderstanding, get over it, and move on
too much attitude
dunno, homercles' attitude was pretty ridiculous.
too much attitude
The OP is apparently graduating from U Texas (nebulous or not, he said i went to U Texas a #9 school), applying to GRAD school, and does not know that a masters is NOT required for phd programs. If this does not make ANYONE with a grad degree say WTF?! You are just as god damn dumb/uninformed as the OP. This kind of sheet warrants "attitude." Someone as clueless as the OP would NEVER be admitted to ANY grad program if was a committee member.
Originally posted by: Syringer
Anyone know of sites that have average GPAs/GREs for grad schools admittants?
Originally posted by: Lazy8s
Now that's all behind us some bumpage for the daytime crew. Perhaps there is a UF masters or phd student here I can talk to?
Ph.D. students without prior CS/CE masters degree can apply for a masters degree after advancing to Ph.D. candidacy and having satisfied all the masters degree requirements.
too much attitude
Straight from the UF webpage:
http://www.cis.ufl.edu/dept/gradcoord/grad-program/grad/phd.shtml#apply
/thread
Edit: Ok, not none at all ever you can go back and get it afterwards but why if you apparently don't ned one? You already have a Phd.
Wow, applying for grad degrees and you dont know that you can/should apply to phd programs?! Fsck, you are horribly uninformed. HORRIBLY, HORRIBLY uninformed. You never should have started this thread. Gawd, im just thinking, "wow, wtf?!"
edit: did you talk to/interact with any profs/grad students the whole time you were in school?
edit2: If i knew who you were i would contact the schools you are applying to and give bad recommendations using my credentials. I cant believe you dont know this ******. I was a postdoc at U Texas and that place is a machine for UGs, but for you to persue a grad degree and not know your options speaks VOLUMES!
That's not what it says. It says you can get awarded the Masters after going for candidacy and meeting the requirements. So if you want, you can get the Masters degree once you've completed all the work for the Masters, but still with your Ph.D work to go.
What actually happens is that you get the masters when you get your PhD. They hate to give you a masters degree if you are taking money as a PhD student and have you leave with a free masters degree. You will get a masters in the end but you cannot get a masters mid-way and bail out. Disclaimer: I was a grad student in the department under discussion.
Originally posted by: erub
I applied to University of Texas and Georgia Tech Electrical and Computer Engineering Departments for admission in Fall 2006. At UT ECE, they had me fill out a supplemental form with these three options:
1. Masters
2. Masters then Ph.D.
3. Ph.D
I chose #2 which apparently was good for lots of $$. #1 probably not so.
GT had a checkbox:
MS/Ph.D.
If you chose M.S., it asked if you were considering Ph.D. afterwards, with the options for immediate/other (explain)
So there you have it..I chose GT MS ECE after getting their TA funding (MS then Ph.D (probably not happening). Add on an MBA FTMFW.
