cusideabelincoln
- Aug 3, 2008
- 3,275
- 46
- 91
One thing these sites don't test is how frametimes are affected with slower CPUs.
I just upgraded from a 2500k to a 3770k, particularly to improve Overwatch performance. And the difference in smoothness is amazing. Here are my settings and performance results. Now if you ask me why do I run such low settings? Well I tried epic settings and I was able to maintain above 60 fps, but there was terrible mouse lag. So I have to maintain a framerate above 100 fps for the mouse lag to be unnoticeable. I also use 120 Hz with lightboost/strobing, so ideally I want to maintain above 120 fps, otherwise there is sometimes a ghosting effect.
The 2500k was at 4.6 Ghz while in these tests the 3770k is at stock. I'm using an R9 280x @ 1080p
As you can see, in both tests I maintain the same average framerate. However the frame time variation is much better with the 3770k, and my bottom framerate doesn't drop as low.
You want to know how I tested? I made a custom match on Nepal. Populated the server with Bots. Played the match for a few minutes until my bot teammates and I pushed the enemy back to their spawn. Respawn timer was decreased and ultimate charge rate increased. I basically kept killing them as they walked out of spawn and used Pharah's ultimate 3 times per benchmark run. This test is as repeatable as you can possibly make it, plus it's also demanding when you have bots popping their ultimates at the same time.
