So i want to update whats happened. First of all my testing methods are not the best. Anyway so when i started the thread, when my video card reached around 70c in bf3 my comp would hang and hard lock. Figured it was the video card and have since been trying to keep it under 70c full load. Well then i decided to download kombuster. I can run kombuster for 10min under 100% load with temps reaching 78c and the computer is fine....wth?? so what ever the cause its only happening when the computer is in full use, i can run prime for the same and no issues with current OC. So now i am thinking the card is fine it must be something else. I wa reading where the 7xxx series card had issues with x58 chipsets. It would cause a sporadic hang. sounds familiar. I installed the recommended build 13.1. But in bf3 for around 5 6 min issue returned.
Ok... So as we suspected, this is not a GPU or CPU temp issue. That leaves us a few possibilities:
1. Something else is overheating. This is my guess since the extra fans seemed to help the issue for a while (or are the issues now also occurring with the fans?). While Prime95 really needs to run for a minimum of 30 min. to give a somewhat valid stability/temperature indication, I'd say the fact that you didn't crash out quickly as you do in-game rules out VRM or CPU overheating. If I had to guess why you'd only see temp-related crashes during "full-system" use, I'd say your northbridge is getting too hot. The only way to know for sure is to test.
2. You have a driver problem. You say you installed the "recommended" 13.1 build, but I'm pretty sure that the latest build for the 7870 is 13.4 or 13.5 (not on my computer or I'd check). Delete the old drivers, skip the auto-downloader, and get the latest driver package directly from AMD's site. You can also try downloading the latest CAP since it contains improvements for single-card setups.
3. Something's fishy with your mobo. I did a little research about x58/7xxx incompatibility, but I quickly discovered that a driver update was released to fix the issue late last year (
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst1211betadriver.aspx). As far as I can tell, there shouldn't be anything inherently problematic about a x58 board and a 7870 at this point.
You now know the card is fine and that the CPU is fine, but it's possible that there's something funny going on with your board. I have no idea what that could be. Unfortunately, the only way to test this theory is to swap boards and retest.
4. You are having some kind of system memory corruption issue. Are you running Prime95 "blend"? Running Memtest for a few hours and watching for errors would be good.
Out of curiosity, do you see any error or critical error entries in the Event Viewer log that correspond to your crash times? If so, telling us the codes and descriptions could help narrow down the possibilities.
