GPU only runs at PCIe 3.0 8x and not 16x
EXCellR8
4,125
936
Interesting... you'd think they'd be a bit more careful about where the labels get stuck. I can understand them being arbitrarily placed on the main part of the PCB but anything near the connector that isn't perfectly placed is definitely an oversight. I don't think I've run into this before though so perhaps it's just a very slim chance. Glad it worked out though.
Markfw
May 16, 2002
27,386
16,227
Also, not an Intel motherboard expert on the later ones, but if you have an M.2 drive, its shares the speed with the primary slot ? (thats a question)
cmdrdredd
27,052
357
Yes and no. You have a total number of lanes on the cpu available and the m.2 slot does share the lanes with GPUs, any network cards, sound boards etc you may have installed. It doesn’t steal lanes but it this is why you can only do 8x/8x SLI with many boards in the consumer market.
Markfw
May 16, 2002
27,386
16,227
Well, thats why I posted. I know the new AMD Zen chips have way more lanes, but without trolling, I wanted to at least propose that might have been the problem.
Glad its fixed now.
Campy
785
171
Not sure but I think the first two x16 slots share the 16 CPU lanes (x16 or x8/x8), while M.2 and everything else goes through the PCH (DMI).
cmdrdredd
27,052
357
The motherboard manual should tel you which ports use the PCH. I think Z370 has a total of 24 with 16 being on the cpu. Generally though the first two PCIe slots share the cpu lanes so if anything is in slot 2 even if it only supports 4x then slot 1 will default to 8x.
Dribble
2,076
611
It won't effect the gpu as that's on the cpu lanes. You've generally got 20 lanes dedicated to PCIE (so you get x16 + x4 or x8 + x8 + x4). The storage goes through PCH which has 24 lanes attached by a 4 lane link to the cpu. Basically for your average user the Intel solution will not have any problems with lack of lanes.
Reactions: Campy
Campy
785
171
I checked my Z270 motherboard manual and it only supports 1x16 or 2x8, but apparently some motherboards can support 1x8 + 2x4.
I found this which shows the PCIe lane layout on the Intel Z370 platform, it's essentially the same for Z270 and Z370:
cmdrdredd
27,052
357
Right...most high end boards have extra lanes on the PCH as mentioned. For 99% of all users this is not a problem
