Ichimura
I have an ASUS Dual-RX580-08G that has two broken fan blades on it, I’ve lost the broken pieces, but I didn’t think superglue would be a good idea. I was wondering if there is anyway to replace this fan? I’ve included a picture.
I’ve emailed ASUS, but they said it’s customer induced damage and want an estimated $230 to fix it.
I have seen replacement fans on eBay, but I wasn’t sure if they would fit or be a good idea. Does anyone have any experience with this?
Thanks for any help.
Harry_Wild
860
169
I have in the past replace my OEM proprietary CPU fan when they begin to make noise. I always take the voltage and amps off of the label and measurements of the dimensions along with manufacture, model number and eBay the manufacturer and model number. You will see that there a lot of parts suppliers that carry that part in the aftermarket.
Just make sure the electrical requirements are the exact same as the broken fan - voltage and amperage on the fan as well as the same electric connector attachment.
Reactions: Ichimura
