GPU for blowout 1080p gaming
Feb 4, 2006
110
7
Modular just gets the cables out of there. Less clutter and better air flow, basically.
Yeah, and the case I have picked out has good cable management...but then again the premium for modular isn't that great at all so it's good advice to give. It could save me hassle routing.
tential
7,348
642
121
I'm trying to dip my toe in the PC gaming waters after a long absence. Not a pro gamer or anything like that. I was joking about the Xbox. I could never abide one of those paddle style controllers. And what's the benefit of a modular PSU aside from hot having cables that I could easily route out of sight anyway? I had a modular OCZ which died and replaced with a non-modular Corsair Bronze on my old box and it didn't bother me. So essentially I chose the non-modular Corsair Bronze this time because that's the one that didn't die on me last time heh.
Good point though, I'm realizing after reading the responses here trying to future proof gaming is a fool's errand. Just get a RX 480, and save money by opting Freesync over Gsync as far as a display goes, and upgrade later when a new game comes out that catches my eye. 480 will run Skyrim and Doom just fine.
I want to get into gaming for escapism after work, not anything competitive.
My main concern is you understanding gpu timing.
If you get that, vendor choice is hard since everyone has different criteria and unless you fully know what you want you're at the mercy of people recommending you stuff.
I say easy rule of thumb, if you buy a lot of games day 1 and are a must have it first gamer, go Nvidia.
If you don't mind waiting... Sometimes forever, get amd.
tential
7,348
642
121
An extra $10 over the full life of a psu that can be used for tons of builds...
I'd fire myself if i couldn't make that decision. And remove all financial certificates I've acquired.
Headfoot
4,444
641
I usually go modular myself, it only really matters that much if you have a particularly small case. In a larger case it will just be an eyesore is all.
Thinker_145
609
58
I don't have a modular PSU because 6 years ago there was still quite a premium on them. However in 2016 there is no reason not to buy a modular one. You know corsair makes modular PSUs as well....
The PSU is possibly the longest lasting component in a PC so no reason to skimp on it when you are not limited by an exact budget.
And yes RX 480 8GB + FreeSync is far better value than 1070 + G-Sync provided you are not going to put the arbitrary restriction of 5 year cycle on yourself. I am sure AMD will continue to do fine for 1080p gaming in the near future.
I personally would buy a 1070 with a non G-Sync monitor but that's because I have never really been bothered by regular V-Sync solutions.
tential
7,348
642
121
All depends. It's such a hard recommendation.
I just day get an adaptive sync monitor no matter what. I can't recommend someone to get into freesync simply because it's cheaper when I'm in the predicament I'm in where I want to 4k game but no gpu to do so with until Vega, where that never happens with Nvidia due to their buttery smooth gpu launching.
You just have to choose what method works for you. There isn't a better option.
I prefer freesync because :
I can wait for gpus through amds insane release cycles
I don't want to fuel Nvidia gsync. I want them to give up and support a standard that works for everyone. Then I'll buy Nvidia gpus more.
More options. I can't buy a monitor I care about with gsync. My monitor I'm using isn't even available from an American company. There won't be a gsync monitor to match my specs forever.
So all depends on exactly what you want.
It's just so hard to decide without the op fully understanding what we do.
bystander36
5,154
132
I agree 8xMSAA is a joke but SSAA is simply amazing. I played Crysis 1 and Metro 2033 Redux maxed with 2xSSAA on a 1070 and it was a glorious experience. Pretty sure neither the 1060 or 480 can do that at 1080p. If I were very rich I'll buy a Titan XP so I could do that in as many games as possible. The whole concept of GPU overkill is a complete joke.
4xSSAA is also really unnecessary. There are overkill settings yes but to get to that point is actually fairly demanding to begin with.
I don't disagree that SSAA is the best form of AA for visual improvements, but it is unreasonably demanding. If you find a need to use it, you will have to spend loads of money unless only used on very low demanding games.
Thinker_145
609
58
It's one more reason why being a year or 2 behind game releases is such a good thing.
bystander36
5,154
132
That is an odd recommendation. Even then, that opens up the another question. Why spend $400 on a GPU, that a $200 can do the same job, without SSAA.
Thinker_145
609
58
Because we care about SSAA?
Staying behind the timeline in terms of games allows you to save money on games, get fully stable games from the moment YOU start playing. Get all the relevant DLC from the get go. And lastly no need to spend too much on hardware for enthusiast level performance.
bystander36
5,154
132
I assume you skip demanding games of their time at the same time? SSAA always remains extremely demanding. Some 2 year old games may handle it, but other 4 year old games won't. You'd have to still stay at the top of the line GPU's to handle SSAA on demanding 2 year old games.
It's important to be able to turn settings down as a PC gamer, and SSAA is typically the first thing that goes.
Edit: and it's fine that you do this, but it doesn't change the fact that that setting, along with a few others, will making gaming much more frustrating and costly.
Thinker_145
609
58
Edit: and it's find that you do this, but it doesn't change the fact that that setting, along with a few others, will making gaming much more frustrating and costly.
I obviously don't play every game with SSAA but I was just saying that if I could afford it I would. Staying behind the timeline allows me various advantages hence I do that. But you are right one has to be really really behind the time to play every game with SSAA at mid range prices.
bystander36
5,154
132
What is so great about SSAA? Hell what is SSAA?
Can I get a Cliffs Notes answer instead of a link to an hour long Youtube vid full of jargon? :)
Super Sampling Anti-Aliasing. It was the original form of AA, which more or less behaves as if it's rendering at a much higher resolution, and shrinks the image down to get rid of jagged edges. It's more complicated than that, but the performance hit of 4x SSAA can be up to the same hit of going from 1080p to 4K depending on the version of SSAA used.
Headfoot
4,444
641
It's a really good looking anti-aliasing. Some AA doesn't get rid of jaggies on certain things. Like you will notice that textures (fences, power lines, trees/grass/brush) have glaring jaggies even with AA on in certain games. That wouldn't happen with SSAA
Head1985
1,867
699
SSAA is Super sampling anti aliasing.4xSSAA its basicaly 4x resolution downsampled.In 1080p its 4k rendering.
Far better is enable MSAA+TRAA(transparency supersampling) in Nv control panel or NV inspector.You get pretty much same quality like 4x SSAA with only 10-20% performance loss vs 4xMSAA alone.But it is working only with games that support MSAA.Pretty much none new AAA game support MSAA or it support like deus ex but it have like crazy performance hit.
Few years back MSAA cost almost zero performance and i can use MSAA+TRAA in most games.today its pretty dead.
Just example how tweak MSAA+TRAA in dragon age origins.You can use this on almost every old game like crysis/crysis warhead and it will look 100x better than only with MSAA.
bystander36
5,154
132
I always found that Transparency SSAA missed a lot that SSAA caught, so I wouldn't sell it as the same thing. I recall DA: Origins showed a significant difference between MSAA + Transparency SSAA, compared to straight SSAA.
It's still worth trying, as it probably is game dependent on how well it works.
Head1985
1,867
699
MSAA+TRAA looks very similar to SSAA/SGSSAA but cost like 90% less performance hit.
I still have old screenshot from dragon age.Pretty much zero jaggies(Hair, sword, armor)
tential
7,348
642
121
Eh, from what I understand about ssaa, if I really need to use that, I need a stronger gpu in the first place. And I'd rather just play at 4k resolution instead of 1080p using ssaa which will do parts at 4k and others not.
Thinker_145
609
58
From my experience with several games SSAA is no way near as demanding as DSR @ 4K. I also don't see the point of 4xSSAA over 2x which further makes the difference between SSAA and DSR massive.
According to Nvidia GeForce Experience 2xSSAA renders the game at 4x the resolution. But even 4xSSAA at 1080p is less demanding than 4K.
dogen1
739
40
2xSSAA is only 2 samples per pixel, you probably need 4x to be comparable to 4k DSR. SSAA is still better though because of the rotated grid, but I doubt 2xSSAA will look as good as 4k DSR.
Thinker_145
609
58
I haven't done IQ comparisons to be honest but 2xSSAA alone looks so much better than 4xMSAA. The 1070 can drop below 60FPS at 4K even on some old games at max settings so I am not really interested in it. I only attempt DSR when SSAA is not possible. And for me sub 60 FPS is a territory I only accept when I have to drop to medium settings.
I'll do a 2xSSAA and 4x IQ comparison with some foliage heavy game.
bystander36
5,154
132
Were you using Nvidia inspector? Did you happen to use the techniques to force SG-SSAA (it requires you to use the transparency settings with Nvidia inspector and a few others settings). Using the standard MSAA + TS SSAA, left more jaggies than SSAA did for myself.
From the descriptions I've read, most 2xSSAA only samples across one grid (horizontal and not vertical). So it's doubles the effective resolution, while 4xSSAA will sample both vertical and horizontal, which is like going to 4K.
dogen1
739
40
Here's a nice comparison tool.
https://www.beyond3d.com/content/articles/122/8
And I'm pretty sure driver forced SSAA uses rotated samples.
