GPU Boost Sucks! How to Disable?
skipsneeky2
5,035
sorry but I dont believe it as again I have tested this on 4 different gpus with various drivers and it did not work in every game.
Rivatuner reporting wrong numbers in 5.2?Could be my selection perhaps as well.Could give Quake 3 Arena a try,also my power target is at 106% if this matters any with target temp at 95c.
Spanners
325
Yikes Hawaii doesn't even have a base, it is all "boost".
Yikes indeed! Seems unrelated to OP though.
@OP
Have you tried using Nvidia Inspector to manage P-states? I used it to manage the clocks of my PhysX card when it was needlessly running at P0 even though it was seeing 5%-40% usage. Worked pretty well.
http://www.overclock.net/t/1267918/...-disable-boost-fixed-clock-speed-undervolting
(This link is pretty much top on Google for "disable boost 680" so it may be old news to you.)
Might be less trouble than a bios mod. It has its own downsides though I'm sure.
http://www.overclock.net/t/1452223/...7-added-tdp-unlock-gtx-780ti-780-titan-gtx770
^ Is worth a look also.
UaVaj
1,546
have seen what nvidia inspector can do to disable boost, however prefer a more permanent solution.
need an expert to translate what nvidia inspector does and make those changes in the bios instead.
fstime
4,382
GPU boost has worked great for me since day 1 with my GTX 680 (overclocked and stock). You sure you don't have another underlying issue?
Spanners
325
Did you check out the bios tweaker I linked? I just downloaded a GTX680 4GB bios and had a poke around.
Looks like you can edit P-states and change the boost table. Usual disclaimers though. :thumbsup:
OCGuy
27,224
37
Using the tips in this thread, my card stays at the selected max clock speed while in 3d apps. No BIOS flash needed.
TreVader
2,057
Hawaii overclocks like every other graphics card ever made before nvidia and their hair brained "offset" calculations. Or have you ever overclocked before?
