meltdown75
- Nov 17, 2004
- 37,548
- 7
- 81
Originally posted by: anonymous1980s
Well, last night I tried marijuana for the first time and hated it. I tried it to see if my suspicion was correct (about not liking it), and now that I have I want to forget it ever happened.
My question is I heard if you have even done marijuana once, you cannot get a government job, is that true?
Let me also clarify that I also was wondering about when you get security clearances for classified information.
Originally posted by: TheShiz
most people have to smoke up a few times before they understand the buddah, give it some more tries.
Originally posted by: Jassi
I was told by a CIA recruiter that if you are a regular or a casual user, its hurts but experimental is ignored.
Originally posted by: rudder
Originally posted by: TipsyMcStagger
10 years?
It binds with the DNA in your hair follicles.
I'll hit on everything.
1) USING MARIJUANNA ONCE WILL DO NOTHING. It takes the 2nd or 3rd use for there to be an effect. And trust me, you'll know it when you feal it. Your suspicion resulted in a possibly false conclusion. You need to feal the effects before forming a conclusion after all.
2) If that's all you did, you probably won't test positive. Drink as much water as you can to purge your system prior to a drug test though. For the prior 48 hours. Rumor has it that Golden Seal Root Herb from GNC helps. I think that's a myth though.
3) Once you pass your test, you will never be tested again unless you provide them a reason to suspect something. Atleast that's how it works where I work. Getting security clearences does not require a drug test. All security clearences do is try to make sure you are not likely to give away secrets. Drug use does not imply that you give away secrets. It will be asked on a form, but you will never (from my experience) get tested/retested.
Originally posted by: preslove
Get a haircut.
Jesus, there's a lot of misinformation here.
Hairtesting is rarely, if ever done. The most common testing method is URINE. THC (the tested chemical within marijuana) is fat soluble (sp?). This means that it is stored in your fat cells. This means that you will test positive for as long as you have the same fat within your system. We metabolize all of our fat in around a month or so, but it depends on the amount of body fat on a person. A skinny dude will take around two weeks to be clean.
As for your security clearance, just say you tried it and didn't like it. I'm sure they get that all the time. Hey Clinton even said that.
Cannabinoids can be detected in the urine for as many as 21 days after use in persons chronically using marijuana because these lipid soluble metabolites are slowly released from fat cells into the blood; however, 1-5 days is the normal urine-positive period.
