Originally posted by: JAG87
Originally posted by: akshayt
Techboi's Minimum Recommended
Intel P4 3.0GHz or AMD 64 3000
1.5GB RAM
256MB Geforce 6800GT or 7600GT level card
Experience: 1024x768 low/low to med settings
Recommended
Intel 4GHz or AMD 64 3700/3800 (Dual Core Recommended)
2GB RAM
512MB Radeon X1900XT or Geforce 7900GTO/GTX or equivalent
Experience: 1024x768 near Max settings without AA
Optimal
Core 2 Duo (X2 @ 2.4GHz, bare minimum I would say, Core 2 Duo strongly recommended)
3(+)GB RAM
512MB(+) Geforce 8800GTX/8800GTS
Experience: 1280x1024 MAX settings without AA, maybe even 1600x1200 or better
MY RIG
AMD 64 3200 Winchester @ 2.4GHz
2GB RAM
512MB Radeon x1900xtx
which category does your rig fall into?
now that you have figured that out,
why the hell do you keep making stupid threads about what kind of performance other people get in the same games you play?
your cpu is the bare minimum required, therefore you are going to get bare minimum frame rates. and NO your video card IS NOT GOING TO HELP YOU. that x1900 is completely raped by the rest of your system. you are probably using half of its real potential.
Do you have any evidence to support this? Granted, his 3200+ may very well bottleneck his X1900XTX much like my 3700+ bottlenecks my 8800GTS. In my experience,
even the most CPU intensive games reveal the GPU's limit before the CPU's bottleneck.
My experiment involved Medieval 2: Total War, probably one of the more, if not the most, CPU intensive games out there. I ran two benchmarks usings FRAPS and identical battle parameters.
A64 3700+ w/X1900XT: 1280x1024
6xAA 16xAF HQ, Huge unite scale, Max everything
2006-12-09 14:07:24 - medieval2
Frames: 8167 - Time: 300000ms -
Avg: 27.223 - Min: 11 - Max: 43
It became painfully obvious to my brethren at the total war forums that they were getting identical performance out of their E6600s...
Core 2 Duo E6600 w/X1900XT: 1280x1024
Avg: 27.9 Min: 20 - Max: 42
And then I got my 8800GTS:
A64 3700+ w/8800GTS: 1280x1024
8xAA 16xAF HQ, Huge unit scale, Max everything
2006-12-18 13:39:35 - medieval2
Frames: 11796 - Time: 300000ms -
Avg: 39.320 - Min: 14 - Max: 60
Sure my minimum framerate was very low in both tests, but when analyzing the distribution data, it was only for a second.
This is M2TW... a CPU sucker. I'd expect to see more of the same with Gotic 3.
