- Jul 21, 2011
- 304
- 0
- 0
Also the reason you take it OUT of the case is because it could be a single standoff is missing and shorting something.
I tried what you suggested, and it does the same thing. Also went back through again and tried moving ram around individually in different slots, as well as GPUs. Even tried an old 7600 GS GPU (PCI-E) that is in my old PC that I know works, and it lined up in the slot perfectly and snapped in place.
I am missing a stand off under one of the motherboard holes, but other than that I got every other one holding it in place, and there are no stand offs out of place and under somewhere that they shouldn't be.
Another thing I noticed was I tried booting up the PC without the 8 pin connector in place, and it does exactly the same thing as it does when it is plugged in. Same error beep and everything. Just to check if my 8-pin chord from the PSU was bad, I had a 4+4 pin chord that I wasn't using for anything, so I plugged that in the 8 pin slot, but it didn't help anything.
Is it possible a bad board fried my CPU? I would be fighting a losing battle, just like it seems I am right now if it turns out my CPU is dead.
I am 100% certain that it is seated properly in the slot, and there are no bent pins, I checked it twice yesterday, and once again today. I even cleaned the thermal compound off the CPU and re-applied it, even though there was none on any of the circuitry.
Is there any way to check a CPU individually?
