Got brakes?
notfred
38,241
4
I've got brand new ones (front pads and rotors, at least) thanks to this. They're supposed to squeak as they're wearing out, but this one didn't.
Eli
Super Moderator | Elite Member
8
In that case, you're supposed to listen for the metal to metal grinding.... :D
Kilgor
3,292
I had to replace the rotors and pads on the rear of my Caprice for the same reason, didn?t know they were bad till I heard the grinding noise no squeaks. :|
tcsenter
18,938
569
Gadzooks! Those are some worn brake pads. hehe
About two months ago, I replaced my rotors and pads in front, rebuilt the calipers, only cleaned and adjusted the rear brakes since the shoes were still good. But, I forgot to spray the new rotors with brake cleaner to remove the protective oil, I just wiped them off good with a rag (but that isn't good enough). My front brakes smoked for the first few weeks and they generate a lot of brake dust from the burnt oil residue. :p
notfred
38,241
4
I did the same thing, but mine only smoked for the first 2 stops I made. maybe I wiped them cleaner than you did.
Zim Hosein
65,398
407
Damn notfred :Q
