Originally posted by: Deftones81
So if VSYNC is disabled the FPS should be identicle even if the LCD can only push 75 htz and the CRT can do 120 at the same resolution? If VSYNC is enabled then the CRT will always ahve the upper hand? Basically my girlfriend bought me a really expensive, low response rate LCD for Christmas and I am trying to justify why framerates seem slower in every game. I will plug the old CRT into it and see where I stand. Sorry about being such a noob.
You are aware that LCD's dont' have true refresh rates that equate to CRT's right?
http://www.techmind.org/lcd/
Quote from above article about LCDs versus CRTs
"Refresh rate is the rate at which the electronics in the monitor addresses (updates) the brightness of the pixels on the screen (typically 60 to 75Hz). For each pixel, an LCD monitor maintains a constant light output from one addressing cycle to the next (sometimes referred to as 'sample-and-hold'), so the display has no refresh-dependent flicker.
There should be no need to set a high refresh rate to avoid flicker on an LCD."
I believe a 16ms LCD response time yielded around 62.5 fps with no problem but that is of course dependent on many variables such as marketing. LOL
