Got a DS Lite today
pontifex
43,804
46
Originally posted by: ducci
Well I have an R4, so I can't be specific about the CycloDS, but it came with no instructions at all, really.
But I would assume the CycloDS uses Moonshell to play movies - all the other cards I'm aware of do. You need to convert your movie files to the moonshell format - I don't have the link on me, but a quick google search will suffice. I haven't done it in a while, but if I recall, I converted a couple episodes of Family Guy and The Wonder Years and they looked fine - converted in about 10 minutes maybe?
I don't use it to play mp3's, so I can't help you there.
interesting on the no instructions part. is it pretty easy and straight-forward to figure out? i guess i'll find out when mine comes.
Yes, the CycloDS uses Moonshell for music and movies.
Was that conversion 10 minutes for each episode or 10 minutes total?
oznerol
2,476
www.lorenzoisawesome.com
It's been a while - I just remember it's quick (the conversion process, that is). I would say 10 minutes for a ~30 minute family guy episode is about right.
These things don't usually need instructions - from my experience with the R4, I would recommend not using whatever CD that comes in the package and go to the website and download the latest/greatest firmware.
Everything else is drag and drop - I hope you have a means of actually getting the data onto the SD card. Once you do, you just copy the firmware files right to the card, then create folders for music/movies/games, and just drop the files in there - the card's software will let you browse it from your DS and everything else you can figure out by just poking around.
pontifex
43,804
46
yeah, my memory card came with a regular sized SD card adapter and SD card reader. I already had a SD card reader anyway.
pontifex
43,804
46
ok, my cyclods came today. currently putting moonshell on it and the firmware update.
seems cool. pretty simple. loads pretty fast. i've tried a few ds romson it and they worked and loaded as quick as if the cart was in.
now my question is can i play roms from other stuff, like NES, SNES, etc?
pontifex
43,804
46
ok, need help with how to make a moonshell playable file. i got 3 programs - dpgtools, batchdpg, and avisynth. tried to encode an avi file with batchdpg and it failed on the audio. dpgtools seems to have worked but it seems a bit complicated with all the crap that comes with it.
no idea what avisynth does...lol
BlueWeasel
15,944
475
SNESemuDS
This is a pretty good SNES emulator for the DS. I've only tried it with a few games, but it works great. There's no noticeable framerate or lag issues.
I've only had a chance to try DPGtools, but it seems to work OK. While watching video on the DS isn't the greatest quality, especially when converting an already compressed Xvid file, I was honestly surprised. It was definitely watchable.
BatchDPG is next on my list to try.
Avisynth is a video conversion program, but I think it needs a front end for ease of use. It's certainly the most complicated of the 3 you listed.
pontifex
43,804
46
Originally posted by: BlueWeasel
SNESemuDS
yeah, i was surprised at the quality. the video i encoded was that I Am Murloc video (some music video with WoW characters). the smallest video i could find on my pc. it was 55mb in avi format and was a little under 13 mb in dpg format. video was pretty clear. there was text with the video and that was hard to read though.
