Good Power Supply.....
Originally posted by: Azsen
Originally posted by: Algere
I said ATX12V 2.x, not ATX 2.x
I've had a look in the ATX12v 2.x spec too and can't find it. 😕
See under "5.1 Temperature" (pg. 37 in your link). So it says "recommended" & not a must like I said in my previous post. Not like I'm gonna remember every minute detail of that spec sheet & I did afterall say "if memory serves".
Since you're posting links, I'll provide a couple links of my own...
Notice "environmental" & what's listed under "temperature"
PC P&C (0°-50° C)
OCZ (0 to 50° C)
If you wanna ask ppl from OCZ (John & Ryder) what the 50° C applies to in that OCZ link, go here. Cause whatever I say, I doubt I'd be able to convince you otherwise.
PC P&C (0°-50° C)
OCZ (0 to 50° C)
Hardly conclusive evidence. Environmental temperature means the temperature the PSU can operate at. In other words the PSU should be able to operate in the range of 0 - 50°C. The spec says absolutely nothing about the PSU having to perform at it's rated wattage output at up to 50°C like you have said.
And that's the point I'm getting at, most PSUs can run up to 50°C no trouble, they are designed to. But most PSUs are rated at 25°C to inflate their wattage rating. So when they hit 40°C (typical power supply temp) then they will drop their wattage load.
Now so far you have not shown me any evidence to prove that an OCZ power supply will do a continuous 520W or 600W at typical PSU temperatures. So who knows how much they actually output when it gets hot inside the PSU?
We get a subtle clue from the OCZ spec sheet that they rated their MTBF @ 140,000hrs but at 25°C. Well it's highly doubtful that the PSU will always be at 25°C. You've got the PSU generating heat, the CPU, video card, everything else generating heat. So that MTBF failure rating is also misleading.
Anyway I have asked the OCZ guy the same question and we'll hope for a definitive answer. All I'm asking for is confirmation, but so far I'm getting none.
PC P&C (0°-50° C)
OCZ (0 to 50° C)
1) Remember that OCZ link stated "Operating temperature" between 0-50° C. Now if I'm wrong, so is SilentPCReview (#3 on the right). I'm pretty confident you'll get the same answer from them [OCZ] as well.
2) If that's so then why would Enermax rate their old PSUs operating temp at 25° C, while their newer PSUs are rated @ a much higher operating temp?
3) Happy?
4) MTBF = Mean Time Before Failure, it's an estimation of the longevity of a PSU @ those temps, not the capability of a PSU @ so & so temps.
5) Give 'em time. It's only 7:41 AM in the eastern seaboard, let alone the rest of the U.S.
