Originally posted by: Shenkoa
If I only had a penny for everytime I seen the the acronym X2 used on these forums.
Originally posted by: Duvie
multitasking what he suggested doesn't need the pretender with HT...and this is coming from someone who trupted them when it was all we had....
"I don't really play games, so game performance isn't important to me."
7800gt?? What the heck part are you having trouble readind???
If he wants status qou then he should stick with single core P4s...step up to a future he probably doesn't realise exist (like many newly created X2 owners...ask Mechbgon)
You have trouble understanding my post. My post said that if A 2.4C was fast enough for him using those applications, the 3.2 P4 will be a noticable improvement. With the X2, he might not notice any difference. It woudl be the equivalent of having him upgrade from integrated graphics to the 7800GT, which is near useless for the things he does. I never suggested that he get a 7800GT. Kinda like having a 1GHZ PIII face off against a 2.8GHZ A64 in microsoft word.
You have your (everyone who attacked) opinion and I have mine. Please stop the blatant flaming of my suggestion.
As for the OP, your best bet would be to try both processors and see what its like. Maybe go to CC and try the X2 and 3.2 P4 out. Ask if you can install any programs, and generally if the sales person thinks that he might make a sale, he would let you (at least thats how it is for my local CC). See if there IS a noticable improvement in the tasks you do. After you try it, you can say they are both too slow and that you are considering a Dell.
I understood the crap you were saying...That pretty much disqualifies you from sounding like you know what you are talking about....
Remember I had a 3.5ghz oc'd 2.4c and the X2 is 150-180% faster in my activity...So spread that FUD elsewhere
Is your activity the same as the OP activity? If you jump off a cliff and survive, will the OP survive if he drops off a cliff?
2 out of the 4 task which still makes better sense then you trying to steer him towards status qou he already has in terms of multitasking ability....
YOur X2 comment was on a level that I just cannot discuss reason with you....It is pointless....I will let the others...I am laughing too hard...
"X2" is not an acronym.Originally posted by: Shenkoa
Just another point to make out. I have never ever said that a 3.2 P4 with HT would beat an X2 in terms of multitasking ability. All I have said is that the OP should check all his options, as he might think that he needs an x2 when all he really needs is just a faster P4.
If you felt that the 2.4C was good enough for you, then something like P4 540 or something along those lines will do just fine. No reason to overspend.
Originally posted by: tstein
I'm looking for a good "work" CPU. I generally run lots of windows on dual LCDs. At any given time, I might have two PCB cad programs running, a couple compiler\debuggers, 20+ acrobat datasheets, and a slew of webpages open.
I don't really play games, so game performance isn't important to me. I want the best solution for work. I will not be overclocking.
Currently, I'm using a Intel 2.4c, which has been a really nice CPU for me over the years. It's been very responsive and generally runs very cool with the retail heatsink. Before that, I had a AMD 2000 (or something like that) that I was NOT impressed with. The heat coming off of that thing was insane. I recall going through 2-3 of them as they were burning themselves up with stock cooling. Heat is a big issue for me...the case is in a wood desk that isn't too forgiving on airflow.
I'm open to either brand, but I want the best solution for my needs. So I don't want to hear recommendations for one brand because it's what you use for gaming and you like it
Thanks!
Tomas
:thumbsup:
Thanks!
Tomas
G'day Tomas!
I'll try to give you an unbiased summation (though admittedly I am biased towards AMD).
From your description, it sounds like any upgrade you make must be towards a dualcore processer. If you're running 2 CAD programs simultaneously, your multitasking needs almost require it! You obviously have a few choices...
1. Pentium D - This will be the least expensive solution IFF you choose the 820D. The cost on an 820D system will be about $50 cheaper than all the others. As to the rest of the Pentium D line, you'll be paying the same or more. The downside to the Pentium Ds is that they run as much as twice as hot as the X2s, and they perform significantly slower for what you want. In addition, they are exceptionally poor at single threaded apps (worse than the single core Intels in many cases).
2. Paxville (multicore Xeon) - The worst choice possible (without contention, even by Intel fans)... Just reading this review should explain why...
3. AMD X2 - Certainly the most cost effective, with performance that is even superior to a 2CPU Xeon system (and we won't even discuss how much better than Paxville it is...).
It also runs at a power and heat level that in many cases is half that of the Intel PD line.
4. DC Opteron - For serious workstations and servers...Opterons aren't cheap (except by Xeon standards, where they are incredibly cheap), but with a single DC Opteron in a dual CPU board, you have the option of adding a second DC Opteron should you require even more processing at a later date...
I don't know if you're planning on moving to 64bit for work, but if you are then don't even consider the Intel chips...while a few of them are indeed 64bit capable, they aren't nearly as efficient/quick as AMD in 64bit. In addition, AMD has an onboard hardware IOMMU for mapping 64bit addresses, whereas Intel must use software because their chipsets don't provide this.
Hope that helped...
Just saying...he doesn't not to overkill if he's satisfied w/a 2.4c.
jmo.
Why don't you let the OP decide ? The difference is so large, that I don't think he can comprehend it. (no offense intended OP). If he has the money, it IS the right processor to get as many of us have said.
hacp, you need to knock off the crap you are spewing.
As for the OP, your best bet would be to try both processors and see what its like. Maybe go to CC and try the X2 and 3.2 P4 out. Ask if you can install any programs, and generally if the sales person thinks that he might make a sale, he would let you (at least thats how it is for my local CC ). See if there IS a noticable improvement in the tasks you do. After you try it, you can say they are both too slow and that you are considering a Dell.
jmo.
Ummm...if he was satisfied, why would he want to upgrade?
Did you read what programs he was actually using? The P4 540 would almost be a downgrade for him...
2) The reason for upgrade is two fold (a) I'm experiencing some strange video lockups that I'm 99% sure are motherboard related. (b) If I am upgrading, I'd like to see an improvement over what I have.
Looks like an X2 model will probably be my best choice. Looks like there isn't a whole lot of difference between the models: 2.0, 2.2, 2.4Ghz in standard and double cache versions. In regular use, is the 400Mhz noticable? What about the double size cache? I realize it would be noticable in benchmarks (which I don't care about).
Is the X2 worth considering overclocking? I have generally NOT had good experience with overclocking for the following reasons: I don't want to spend time tweaking voltages and running stability tests. I use only the retail fan\heatsink. The ONLY way I would be interrested in overclocking is if there is a particular setting that I will be able to run it out with very little to no messing with. Is overclocking (based on my willingness to F' with it) something I should consider?
Is xp 64-bit version something I should be buying with an X2? Or stick with my regular licensed xp pro?
Thanks for the detailed breakdown Viditor. That gives me a good idea of what the current picture looks like.
Hacp is correct. The main reason for the upgrade is the fact that I've got a motherboard resulting in semi-random video lockups. But, I'm certainly leaning toward an upgrade. Although a faster HT processor similar to what I have would do the job, I've got a few more bucks lying around that I'm willing to put into something that will provide a larger increase in performance for what I'm doing. X2 certainly looks like the obvious choice that is in my prefered price range.
That isn't to say that suggesting the 3.2Ghz version of what I have isn't a valid solution. I appreciate the suggestion and if my motherboard wen't the main thing and I were still looking to squeeze some more performance, this is probably the route I would go. Leave hacp alone..jeez
Thanks
Thanks
