Good HT 5.1 system for $600?
audionoobie8954
Hi all,
I am looking for a good 5.1 Home theatre system. Primary use will be mostly Satellite HD DVR, some blu-ray movies and some music from iphone.. My budget is about $600. This should cover the AV receiver and 5.1 speaker set.
Some basic research has yielded the following options:
1) Onkyo HT-S9400THX 7.1-Channel Network A/V Receiver/Speaker Package (Bookshelf)
Onkyo HT-S8409/7500 7.1-Channel Network A/V Receiver/Speaker Package (Tower)
2) Yamaha YHT-897 5.1-Channel Network Home Theater System (Tower)
Since this will be my first HT and I am a newbie, please recommend which of the above or something similar would be best for me? The Onkyo with thx and the yamaha with airplay both seem attractive. I am probably ok with pairing different AVR and speakers if there is significant difference. I am looking to buy in Feb '13 so prices are likely to hopefully reduce by then.
I plan to also buy a 40" LCD-LED TV (no 3D) to complete my HT system. (budget is $500)
Thanks again
Vdubchaos
10,408
10
People have been recommending these items in here. Very good budget systems. Superb values. I think you would be hard pressed to find better for the price.
Jamo S426 speaker package $169
Denon AVR 1612 $189.00
I am sure somebody else can recommend a decent sub woofer.
Probably this + PSW505 Polk Sub ($180-200)
Denon/Yamaha or Pioneer all have sub $200 receivers.
Some other options:
Polk Monitor 30s Bookshelves ($60-70)
Polk CS1 Center ($60-80)
And just wait to get the Monitor 50 or 60 Towers down the road/move Monitor 30s to the back.
I paid $80 a pop for Monitor 50s....
Don't bother with Onkyo or Yamaha speakers.....both Polks and Jamo are great options
cheez
1,722
69
OP,
Get the following:
- PC soundcard (you already have one?)
- Subwoofer that accepts RCA inputs
- 2 pairs of Audioengine A2 speakers ($400)
- Audioquest Sydney 1.5m ($200) going from PC soundcard to A2 speakers
- Audioquest Sydney 1.5m ($200) going from PC soundcard to subwoofer
So that's at least $800. Save up more money to get them. This is a fantastic super high quality sounding 5.1 setup. You can thank me later. ;)
Vdubchaos
10,408
10
^^^^ That's a great idea. Blow 2/3rds of your budget on cables!!!
And where are you getting 5.1 from? Unless math standards have changed that sounds like 4.1 to me.....Also sub woofer cost will add to your $800 budget which is already WAY beyond what OP stated.
Anubis
78,712
427
tbqhwy.com
just add cheez to you ignore list right now and save yourself from the moron
the Jamos are nice,
the pioneers linked below would be another good option, however slightly more expensive
Towers
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Home+Theater+Speakers/SP-FS52
Center
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Home+Theater+Speakers/SP-C22
Rears
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Home+Theater+Speakers/SP-BS22-LR
as for subs the Bic F12 is a pretty decent budget sub - can be had for 200 ish when on sale
Number1
7,881
549
OP,
Get the following:
Audionooby8954, please disregard anything Cheez is recommending.
Cheez:
Your recommendations are a fraud, an abomination, an insult to anybody with a brain.
Audionooby8954, Cheez is known as "IamAnoobieChee" @ the AVS forum. Check this thread to find out what he is all about: Link
boomhower
7,228
19
Denon 1612 refurb from accessories4less $190. (Adyssee will make whatever speakers you get sound better)
Polk Monitor 60 x2 $200
Polk Monitor 30 $80
Polk CS2 $100
Speaker on sale at newegg.
That's going to eat up $600 once you pay shipping. That'll get you started though. Save $200 and get a BiC F12 sub and you'll be set. For the money I can't think of a way to get better overall sound.
If you wanted to do it all at oncethe previously mentioned Jamo set with the Denon receiver and BiC sub would be a good set-up. The Polk 505 sub is also good and on sale at newegg for $190. If you it's primarily music I'd go with the Polk sub but if movies/gaming I'd get the bic.
