- Oct 22, 1999
- 1,655
- 10
- 81
Fitting the Corsair H100i V1 AIO into the Ncase M1 chassis has been a hassle. I'm going to use instead the Noctua C14 HSF for the i7-6700k. (should have it by Wednesday)
I also have 2 Vardar F4-120ER and 2 Noctua NF-F12 fans as well. I don't have the slim Noctua 92mm. I probably will not OC the i7-6700k CPU. And I have the nVidia 1080-FE model (exhausts air out)... and no traditional hard drives either, just an SSD.
So, with what I have for fans and the components I'm using, is there an ideal setup for the cooling for this very small Mini-ITX case? ( https://www.ncases.com/ )
