going snowboarding for the first time.. what to bring
skim milk
5,784
winter seems like it's already coming to an end... the weather hasn't been too cold lately
I don't think I need my thick and heavy northface jacket
I heard I can borrow clothes from the shop there... can I wear jeans?
Do I need a beanie? a goggle? and etc..
DBL
2,637
As a first time snowboarder, jeans are probably the worst thing you could wear. You will fall and get very wet. Get a pair of waterproof ski/snowboard pants.
skim milk
5,784
also is there a snowboard size I should rent?
I'm about 5'11 and weigh 145lbs
thanks
L
Lola
motrin.
Seriously, the first time i went snowboarding, i was in a lot of pain afterwards.
I personally don't like wearing jeans while snowboarding/skiing because they feel too constrictive.
Do you have layers like thermal underware and then jogging/running pants to put on under? Its a lot more comfortable like that.
Get a hat and some sunglasses and you should be fine.
leftyman
7,073
thanks
ive never seen an Ethiopian snow boarder :D
geecee
2,383
43
Definitely waterproof pants of some sort as everyone here has suggested. You might also want to pad that with some sweats or something as you will be on yuor backside quite a bit.
skim milk
5,784
thanks
I may on the lean side but I consider myself in shape... it's all muscles except my adductors :p
leftyman
7,073
thanks
get that thighmaster yet ;)
TheGizmo
3,627
snowboard
boots
gear to keep you warm, face and eye protection.. gloves
snow hunny
condoms
booze
Scarpozzi
26,392
1,780
You'll be going really slow, so you won't really need goggles, but they can't hurt because they stick to your face and prevent glare. (I recommend amber colored lenses)
Get a helmet. If you catch an edge while learning to turn, you can fall backwards and slam your head on ice if the slopes have any icy spots....
Other than that...pad your knees and your backend as much as possible, but stick to wearing padded snowboard pants if possible. They should be made out of thick, but light material. I prefer Black-Dot as a namebrand. They usually have some decent equipment for cheaper than the names like Burton, etc...
Don't worry about your snowboard, boots, or bindings. When you go to rent, they'll hook you up with what you need. Just remember to pace yourself....and get wrist guards if you have a tendency to put your hands in front of you when you're falling forward.... With snowboarding, you're better off learning to roll and take the fall without putting your hands out. Broken wrists are common injuries.
If it's really cold out....like 2 degrees and blowing snow in your face at 30mph, you should look like this. Link
gigapet
10,005
water proof gloves and pants are a must.
The rental place will hook u up with everythign else.
Take a lesson.
GasX
29,033
You need water/weather proof pants as you will spend most of your first day on your ass. If you are in the northeast, bring padding too...
davidsi
567
i got some wrist protectors the frist time i went. they helped a lot. therye about 20 bucks at the stores.
Strk
10,197
4
You never wear jeans while snowboarding/skiing. Cotton doesn't help you keep warm.
Anyways, you will want to bring some waterproof snowpants, because you'll be on your ass a lot. As far as board length, probably around 150. It's been a long while since I've been, but I haven't grown in ages, so the size is about right, if I remember correctly ;)
clickynext
2,583
Padding, waterproof stuff, and if the snow is rock hard, ice-like, might consider not snowboarding, because last week I almost broke my wrist trying to do it, just from repeatedly falling on it on the hard ice, and it was my 3rd time snowboarding.
