DrPizza
Originally posted by: MikeyIs4Dcats
ask DrPizza, IIRC he has done tutoring.
I rarely do any tutoring... I help students after school when and if they come in, but that's about it.
However, I've posted help to quite a few problems in here, and in highly technical (but don't use that forum to post homework problems)... quite often, I've seen posts requesting help with problems... usually they receive about 20 answers - 15 nefs saying "do your own homework", and the rest attempt to help. If the problem hasn't been answered, and I can answer it (and have the time to answer it), I usually do. If it requires a diagram or something for the explanation, then it's a 50/50 shot if I'll take the time to draw one.. Good luck, line up a tutor, it's hard to say if you'll need one or not. I've always felt calculus is easier than pre-calculus (so long as you've mastered the pre-calculus skills.) It seems to me that the hardest part in the beginning is probably understanding the definition of the derivative.. After that, it's just a bunch of rules to remember.
Oh, and here's one for you... when you learn the quotient rule, use this:
ho d hi minus hi d ho all over ho ho
It's a lot easier to memorize in that form! Far easier than saying "the denominator times the derivative of the numerator minus the numerator times the derivative of the denominator all over the denominator squared." (you can make sense of it when you get to that point.)
