VirtualLarry
I would think that the real reason is that they are a static load, mostly purely resistive in nature, while PC power requirements are rather volatile and dynamic. Not just that it's hard to start switching-up the connection of various bulbs to more correctly approximate an "evenly balanced" power draw across all of the rails. I saw one of the review tests on the internet, used a mixture of both - some bulbs for increasing the overall actual load, combined with running an actual PC at the same time to more accurate test the dynamic-load behavior. That sounded like a decent compromise to me, for a home-made MacGyver-esque testing rig.Originally posted by: jonnyGURU
So light bulbs are out. Too difficult and expensive to properly regulate.
"Good" as in "accurate and correct way to test a PSU", or "Good", as in, "politcally correct review - don't want to single out any particular company and make their product look bad"?Originally posted by: jonnyGURU
I took a couple days off from work and drove up to his office where he showed me an actual PSU testing machine (SunMoon SM-268) and we did a series of tests on some different power supplies.
He had told me that the only "good" PSU test online was the one that Tom's hardware just did. But I was feeling a bit let down about that opinion because they only "benchmarked" efficiency at different loads, gave an aesthetic overview of the PSU and then concluded "none of them blew up." How is that a good review?
Hrm. I would have to research this more, but I wasn't aware that the UL guys actually tested the accuracy of the specs of the PSU, I thought that their only job, more or less, was to test the safety issues of the supply, whether or not it would burst into flames, withstand high-voltage arcing, shut itself down if overloaded, etc? So just because it has the UL number, doesn't mean that the supplies' mfg ratings are "accurate". (But it does mean that the mfg cared enough about the quality and safety of their supplies to submit it for testing, and that helps differentiate those supplies that even have approval at all, from those bottom-of-the-barrel ones that don't.)Originally posted by: jonnyGURU
He told me that if you actually know how to use the test equipment and what a good "balanced" number for a power supply's given specs is, you can load a PSU up to 100% load for eight hours and not have a single problem. Tom's review was only trying to be "fair and balanced." Nobody isn't going to load a power supply to 100% load for any prolonged period of time. And all of the power supplies tested, ANY power supply that is UL listed, is GOING TO live up to it's label.
I especially wonder about that, with regards to continuous-load numbers, since many cheaper (but UL-listed) supplies don't even list the continous-load numbers, only "max" load numbers, with a caveat about max load being sustainable only for 10ms or something like that. So given that, how would the UL guys even theoretically be able to test a continous load for eight hours, if they don't even know what that load is supposed to be! So, color me skeptical on that scenario.
*chuckle* Sounds like a good plan to me. 🙂Originally posted by: jonnyGURU
So what aspects of a power supply do you test? Features and efficiency.
So he's saying to buy a power supply based on features and the specs on the label and if efficiency is important, look at that as well?
Hmm.... Not good enough for me. I like blowing stuff up.
Hey, no fair, I thought that you said that you were going to blow stuff up? 🙁 🙁 🙁Originally posted by: jonnyGURU
We tried to knock a few tests out.... We did an OCZ, an Enermax, a PCP&C, Antec and Ultra X-Connect and X-Finity before we ran out of time (it was getting late and I had to get home so I could go to work in the morning.)
Much like THG's review, all of the aforementioned power supplies handled the full loads I hit them with as per their label... AND THEN SOME. Some characteristics are worth noting and that's what I'm doing here. ALL of these power supplies are VERY GOOD despite smell, heat and small puff of smoke. 😉 NONE of these power supplies should be frowned upon because in the end, they were ALL run OVER label specs, and like I said, none blew up.
(I'm with Zepper on this one - test 'em till they die. That's the only way to find out how much actual "headroom" there is. Much like testing CPU frequencies for "binning".)
Still.. did you have an O-scope hooked up, to gauge the regulation/voltage-swings, under heavy load? Just raw load-testing doesn't do all that much good, not only does the supply have to supply the power, but it has to be stable enough to use. Most of the cheaper supplies will supply that much power, in the absolute sense, without blowing up (hopefully - as long as they are UL listed), but that power may be too unstable to use. That's the key metric as far as I'm concerned (once you get past the, "didn't explode on the test-bench" stage).
That's very impressive, and proof that those supplies (and the Fortron units that they are apparently based upon), have a lot of extra "margin" in them, that the cheaper supplies don't have. But that's also why they cost as much as they do. :|Originally posted by: jonnyGURU
The PCP&C sat there like I didn't have a load on it. 😛 Seriously. The rails never fluctuated and it never got hot. I actually laughed out loud. Even though the power supply was 510W, it was doing 600W easy and the 12V was at 12, the 5V was at 5, etc. Too bad the power supply costs $225!
(I am slightly curious about the "never got hot" part, I thought those had a reputation for "running warm"? Just wondering if perhaps the "on" button didn't get flipped for that test... was it even warm at all?)
See, that's actually interesting. Back in the day, the +3.3v/+5v lines were "combined wattage" (as you will see on most labels). Based on your testing, it seems as though the +5v/+12V on those Ultra X-Connects may be "combined wattage" instead, which would perhaps explain a few things, and how they manage to pull off such a high rating on each, based on the size of the components used to build it. (Going by rule-of-thumb here, not really scientific, but I hope you can get what I'm suggesting.) That actually could make some sense, as these days, either the +5V, or the +12V, is going to be loaded heavily, but not generally both. That might also explain, partially, failure under testing, if this +5v/+12v-combined issue wasn't taken into account. I would attempt to follow up on that with your contacts at Ultra and their engineers, to find out if that is indeed the case.Originally posted by: jonnyGURU
The X-Connect was the most stable on the heavy 12V, but had the biggest +/- going from idle to full load. Always within spec, though. The 5V test sent the 12V into a serious dip, but the Ultra is engineered with a high 12V for Prescotts and SLI, so that didn't surprise me. There was a slight smell, but not as bad as the Enermax. When we shut the machine off, I did so suddenly after the full load. I guess I learned that I need to gradually let the PSU down because the sudden stop of the fan caused a sudden concentration of heat, which resulted in a small puff of smoke. Now I can see why Raidmax's ECASO (Enhanced Cooling After System Off, where the fans spin for three minutes after power off is so important. 🙂 After the PSU cooled back down, I fired it back up and it seemed to be OK.
As far as the fans running after the PSU is shut off, I've wondered about that too, and not just the PSU, but the CPU heatsink's fan too, on some really high-powered systems, and even a bank of actively-cooled HDs. Killing fan power will allow their temps to briefly spike before settling back down. (Same reason most cars these days will continue to run the radiator fan off of battery power after the car is stopped, especially on a hot day.) I would like to see that feature implemented on more systems in the future, it sounds like a really good idea on the whole. It's good that you brought up that issue. Hopefully more PSU makers will take note.
Hrmph. Sounds like this company had no business testing PSUs, or running a PSU testing jig off of a non-dedicated circuit in the building.Originally posted by: jonnyGURU
He nodded and with the 12V already at 30A, I started taking the 5V up from 20A. I don't remember exactly where the amperage was at for the 5V, but I remember seeing 700W on the load tester and just over 900W at the AC outlet when the lights went out in the office. I guess between the PSU and all of the other test equipment on the same outlet, we pushed the wiring in the building beyond IT'S capability and the breaker tripped. 🙂 My friend then told me that that was to be expected because the X-Finity 600W is essentially two 400 or 450W power supplies mounted on top of each other and then "underclocked" to a total 600W so it didn't get too hot. Nice. 😉
Oh, ok, I take that last comment back, if these things are meant to be portable. I guess they aren't quite as physically large as I had assumed? (Size of a beloved patriot-tonk piano? Smaller? I guess...?)Originally posted by: jonnyGURU
He said back in Taiwan, they have racks loaded with these so they could test several units at a time. He could lend me one unit as long as I reported to him with any findings, problems, etc. So now I'm back at work with a SM-268 in a cardboard box sitting in my trunk. I will have to take the family to the fair on Saturday, but come Sunday I'll be hooking all of this stuff up and will continue testing power supplies.
If anyone has any questions or wants me to try anything, please ask! And Anand... if you want to do a PSU shoot out, let me know! 🙂
