nitromullet
Originally posted by: n7
Well buck, i'm not sure what your problems were, but nVidia does tend to have crappy drivers.
It seems they keep getting worse & worse...or certainly not better anyway.
As opposed to whose..?
You would be making a bad guess, I have dual 2005fpw's.
You have a very low resolution slow monitor and you are expecting what....? You think that drivers are going to speed up your processor or make your display any good for high end gaming? That isn't going to happen.
What are you talking about? Maybe you should read the posts before posting 😕.
1. 1680x1050 is not low resolution and it has 16ms response time
2. Where did i say drivers should speed up my processor?
3. Sharky extreme lists the 2005fpw as their lcd for "Monthly Extreme Gaming PC Buyer's Guide". Not to mention that alot of gamers on these forums choose the same.
I dont know what crawled up your butt, but if you arent going to post anything helpful, go away.
*edit*
I forgot to mention that i have a sony g500 21" crt, and i prefer gaming on a 2005fpw.
It wasn't years ago, for the hardware you are talking about it is. There isn't much use in buying a top tier video card for a low res monitor. Some benches to look at. Why spend the money on a 7800GTX with a monitor that has such low resolution capabilities?1. 1680x1050 is not low resolution
If you are hoping drivers are going to make a larger impact in terms of performance in relation to the x800xl you had previously. The 7800 is overwhelmingly CPU bound at lower resolutions- newer drivers aren't going to help this situation out too much.2. Where did i say drivers should speed up my processor?
I never said it was horrible by LCD standards- I said it was low res and slow both of which are true when talking about a high end gaming display.3. Sharky extreme lists the 2005fpw as their lcd for "Monthly Extreme Gaming PC Buyer's Guide".
That at least handles mid level resolutions. Run your games on that with settings put to 1920x1440 4x AA/16x AF and compare you XL to your GT and you will see a much larger difference in performance then what you are seeing now. That will have a much larger impact on relative gaming experience then any newer driver is going to.I forgot to mention that i have a sony g500 21" crt, and i prefer gaming on a 2005fpw.
*edit*
That is because you have never owned a good CRT. Proud owner of an Iiyama Vision Master Pro 450 🙂Originally posted by: southpawuni
*edit*
Dont mind him.
I know CRTs suck. Which is why I dont have to go around trying to prove it to everyone.
:heart: 2005FPW
*edit*
Dont mind him.
:heart: 2005FPW
1920 x 1440 / max. 75 Hz .. 640 x 640 / max. 180 Hz
Still would like the Dell and retire the CRT (it is > 7 years old).
I have a sony g500 sitting behind me on the floor collecting dust because its not as nice as my 2005fpw's IMO. It supports resolutions up to 2048 x 1536 @ 75Hz. Lets not turn this into a pissing match, as we all know, its personal preference.
i think you're missing the point here.. what he is trying to say is that at "lower" resolutions, you won't see much difference between an x800xl and 7800gt in most games. since your crt supports much higher resolutions, you could run at "higher" res where the 7800 could stretch it's legs and offer much superior performance to an x800xl.
until the "next gen" games hit where the target system specs are higher, you're just not going to see much performance difference in this gen and last gen's high end cards (and this often applies to dual gpu setups as well) unless you run very high res/aa/af.. that's just common sense.
it's not about whether your lcd is better or worse than your crt, simply that (realtive to your crt) your lcd supports "low" resolutions.
No worries buck.Originally posted by: buck
BTW, if you go to iiyama's US site, those many 40" LCDs in the PIDS section are ours. 😀 And the 46" looks great doing 1080p HDV with a X800 Pro (hey, it was the top of the line card at the time we were working on it.)
And the day is neigh where the LCDs will smoke CRTs and then some. The big hint is in the X1800 with dual DVI at higher res (not sure that the 7800 line matches it - the very sparse info on the dual DVI stepup has yet to be tested - next week maybe?)Originally posted by: buck
That comment was directed toward gsellis. As far as bens point. I got it, but what he failed to understand is that I dont want to game above 1680x1050, that is the resolution that i want. I upgraded to the 7800gt for gaming in that resolution. I would like to see someones screen shots of day of defeat source in a higher resolution (high for ben) like 2048x1536 with playable FPS with details turned up.
And btw, 1680x1050 is not a lower resolution in the gaming arena for newer games like cod2 and day of defeat source.
cevilgenius - What drivers, what resolution, what application? So far, there is nothing here to help you. Throw us a friggin bone.
I never said that i was hoping for a big gain on performance with nvidia drivers. I upgraded from my x800xl for games like dod:s and cod2 (and future games as well).
Do you compete in pc games? (ie counterstrike,quake3,etc)
What are your gaming specs?
Have you played COD2 demo or DOD:S?
From your enthusiast standpoint you might have a fighting chance of getting people to believe 1680x1050 is "low resolution".
16x10 is low res to you, so 1920x1200 must be mid res, and 2048x1536 must be high res.. or something!
I totally disagree with the idea that 1680x1050/1600x1200 is "low res"
1600x1200 4x AA and the 7800GTX is getting only 53.4 FPS in BF2 Demo.
16x12 is low, 19x12 is mid, 20x15 is high. Oddly enough, I haven't found a newer game that my system can't run at high resolution that is enjoyable(shooters are in an enormous rut and strat games are far less intensive). Really hoping that some of the games on the horizon change that perspective.
1. 1600 X 1200 isn't low by any definition used by the overwhelming majority of users. If you must specify a low, then 1024 X 768 is far more accurate.
2. 1900 X 1200 is a widescreen resolution and should not be used as a median of the 4:3 resolutions you mentioned. A more accurate statement would have been to compare all 4:3 ratios for your low, mid and high resolution. For instance, 1024 X 768, 1600 X 1200, and 2048 X 1536.
3. 75Hz refresh on a CRT is too low. I am not sure if any CRT's are able to handle 2048 X 1536 @ 85Hz or higher, but I know that would be a requirement for me and many users. In addition to that, the low refresh rate kills image quality for these eyes and also makes the display noticably dimmer.
Have to keep in mind that many gamers also use 800 X 600 at times, though that number is probably lower. I would say the majority of users out there tend to use the 4:3 ratio of 1024 X 768 and the 5:4 ratio of 1280 X 1024, which I personally hate. People who game in 1600 X 1200 are in the minority, though not as much as the extreme few who run at 2048 X 1536...
Widescreen is a another animal altogether. Especially since widescreen is 15:9, 16:9 or 16:10... Widescreen is relatively loose in defination. I personally game widescreen, and I love it.
