Originally posted by: BassBomb
Wonder w hat all the taxi drivers + police officers do, Impalas were used alot recently for police cars
OH GOD PEOPLE!!!
There is nothing really wrong with the cars. When cars get old they might leak oil. As such there seems to be a place it could pool and then spill, due to hard braking, and maybe catch fire.
I have seen a lot of cars smoke and even had some catch small fires due to oil leaks. Had to replace a cam cover gasket on a 944 as a little leak that could not even be seen caused a fire. The gasket had a very small opening and that was enough.
The problem here is these cars are FWD so if the front head is leaking any oil and you brake hard it will push/fling it forward to the exhust manifold and run down toward the sprak plugs. You even see that they are only replacing some spark plug wire retainers. So they will not fix your old car if it is leaking, just fix where the oil leaks to.
OH GOD PEOPLE!!!
Originally posted by: thomsbrain
Ouch, bad timing for them to have to pay for this. Sounds like a cheap fix, at least.
Originally posted by: Bignate603
Originally posted by: LOUISSSSS
i'm just letting GM know that this recall wasn't so bad.Originally posted by: MIKEMIKE
Louisss, stop trolling, honestly, it is getting very old.
Is that because it isn't as bad as Toyota recalling their trucks which break in half?
this thread is about GM recalling. stick to the topic noob
There's the old saying about the pot calling the kettle black.
As soon as someone brings up something that you don't want to hear that you have no response for (intelligent or otherwise, usually otherwise) you say that we're changing topics. Whenever some thread comes up about something else you can rant and rave about whatever you want. Seems like a bit of a double standard, doesn't it?
Originally posted by: bruceb
What really needs to be fixed is replace the Valve Covers with metal ones, instead of that shit plastic and also new Valve Cover Gaskets. Then you will not have an oil leak and nothing to be worried about. Best advice, keep an eye on the valve covers, especially the front one where you add the engine oil for leaks. If you see any fix it. Not hard to get to the front one. Back one is a little hard to get to. And I own a 1999 Grand Prix with the 3800 NA Vin K motor
