Originally posted by: Ornery
Hold them with mouths down, tap up against the rim of the mug sharply with a wooden spoon or similar sized block of wood. Be ready to catch the glass IF it drops free.
Originally posted by: timcheng00
nitemare: the base of the glass is hexagonal so theres no problem with an air pocket if youre wondering.
also, the glass budges sharply between two positions now, if i apply a pretty considerable force, so... i'll continue waiting it out.
how exciting
Originally posted by: Nitemare
Drill a hole through the bottom of the coffee cup to release the air pocket
Tell your mom it was like that when you found it.
Originally posted by: bootymac
Leave it like that, it'll be a kickass muglass
that's what i'd do 😀
or you could always whip out that peen you've been hiding in your toolshed 😉:Q
Whip out your peen, then.Originally posted by: bootymac
Same thoughts, same avatar, same age... I'M IN LOVE BATMAN :heart:
completely stuck. soap/oil doesnt seem to do a thing
Hold sideways, tap on ccunter.
tried the microwave after it still stuck after sitting for a few hours. it actually only budged twice and will budge no more.
troytime's suggestion sounds interesting though... the freezer one, that is
Rapid change in temperature will possibly shatter the glass
🙂Originally posted by: troytime
if the bottom isn't round, it's not being held in there by a vacuume or waterseal
put just enough water in the mug to touch the bottom of the glass
put the whole concoction in the freezer
