Glass half empty or full thing....finally settled.
FDF12389
5,234
7
Its neither half empty or half full, the glass is just currently twice as large as it needs to be.
lxskllr
60,424
10,810
I'm a realist. It's 1/2 of a glass of water without judgment either way.
oboeguy
3,907
Engineer's perspective FTW.
Rebasxer
1,270
What if you just saw the glass with no one around. It could be half drunk or it could be only half poured. Hense the expression
GaryJohnson
940
Originally posted by: FelixDeKat
Originally posted by: her209
Can a window be half-open?
Only if you see someone moving it one direction or the other. Windows dont open and close by themselves.
So if someone opens it half way, then walks away, it's not half open?
Only if they opened half way.
But if you didn't see wether the person that manipulated it was half opening it or half closing it, is it still half opened or half closed? You wouldn't say that it's open because it's not all the way open, and you wouldn't say it's closed because it's not all the way closed. So what would you call its current state of half openy closedness?
AstroManLuca
15,628
If it's a glass that gets wider at the top, it's probably a little less than half full if it appears to be half full. Because the top is wider than the bottom, the halfway point for volume is above the halfway point if you just measure the height of the glass with a ruler and cut it in half.
