RussianSensation
- Sep 5, 2003
- 19,458
- 765
- 126
The chip you are describing is going back to Fermi. The node is exactly the same 28nm. How do you increase functional units between 50-87% and stay at a reasonable power consumption level while nearly doubling the size of the die?
GTX280 @ 65nm = 576mm^2 GPU clocks of 602 mhz
GTX480 @ 40nm = 520-530mm^2 GPU clocks of 700mhz
Average power use:
GTX280 = 136W (peak of 171W)
GTX480 = 223W (peak of 257W)
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_480_Fermi/30.html
GTX280 = 32 ROPs, 240 SPs, 80 TMUs, 512-bit bus
GTX480 = 48 ROPs (50% more), 480 SPs (2x more), 60 TMUs (25% less), 384-bit bus (25% less).
A full-node shrink wasn't even enough to stop the power consumption from going past 250W at load. Notice how GTX480 is a smaller die than the 280 and despite a full node shrink, the power consumption went up 50%!!
Right now GTX680 uses 166W on average, with a peak of 186W. The die size is 294mm^2.
This is what you are proposing:
50% more ROPs
87.5% more CUDA cores
87.5% more TMUs
2x the memory bus width increase
520-550mm^ die size (or at least 77% larger)
Additional full compute functionality eating up more transistor space since this is inherent in the GK110 architecture (meaning introducing dynamic schedule, etc. since you can't just remove that from GK110)
All of that at 850mhz GPU clocks on the same 28nm node? Really? I need to know how NV will keep this chip under 250W of peak power OR we are back to Fermi days. That's pretty interesting since Performance/watt was NV's focus for Kepler from the beginning. You are saying they will throw it all away and make another 250W card with a jet engine blower fan?
Average power use:
50% more ROPs
87.5% more TMUs
