I've said it before and I'll say it again.
Anandtech's webservers run on MSi K7TPro's with 1Ghz TBirds. That should be stable enough for anybody.
Avoid the Pro2A the Via ATA100 south bridge seems to have quite a few problems, and you don't need ATA100 anyways...the Pro or Pro2 ATA66 boards should be more stable than you'll ever want.
You can set your RAM at 100Mhz or 133Mhz so your current RAM will be fine.
I don't know how fast your CPU is...maybe you want to keep that to and try for an i815E board...I'd say Asus or MSi for i815E boards.
